Looking at a Tomei Extreme Ti cat back exhaust system but want to confirm what the ID of the rear muffler is. Has anybody actually seen one or own one...measured one?
I understand the tube diameter is 89.1mm OD, just want to make sure the muffler does not drop in diameter to 3" etc
  • Replies 100
Yeh, but if I am spending that much money on an exhaust I dont want it to cost me a single bloody kw. I only make 250 odd :( I have some prices for some thing guage stainless mufflers and pieces and if I cant get a solid answer on this exhaust will be going twin 2.5" with a 4" dump with wastegate plumb back in. I currently lose around 6-7% of my power when I plumb the gate back in so need to improve over the HKS Hyper i currently run
the solution to your power woes??
open up that screamer :thumbsup:
fab up a removable piece so you can remove it and reinstall at anytime which shouldn't take long to do.
I don't know how anyone can drive on the road with a screamer, I only lasted a few days of not being able to boost at all for fear of instant defect, car crushing, death by firing squad on the side of the road. But then I do live in Victoria...
Tracks have DB limits too, on some cars they dump the exhaust out different sides depending which side of the track the pits (read microphone) sits. An open screamer would have no chance.
must be a Victorian thing.
Wakefield and Eastern Creek in Sydney, don't have noise restrictions.
wakefield does have noise restrictions, there is a mic in the middle of the grass patch near the main straight.
but they allow open screamers, your car must be insanely loud for them to pick it up and kick you off the track.
ok i just checked the wakefield regs, it says max limit is 95dB at 30m,
they must be very lienant with this as ive seen alot of GTRS/V8/cars with open screamers go there without an issue.
Noise can vary in DB with something a simple as a wall.
Most tracks have restrictions. And then also some have "X" amount of "unrestricted" days.
Just a matter of if you get pinned or not, and that depends then on the position of the pickup
Bris, Buy a 3.5" Borla/Magnaflow etc Stainless muffler from Summit/Jegs take to a decent exhaust shop and have a system made made, wont be titanium, but wont be any doubts about the muffler quality either
+1.
In fact just got a new full 4" system using Magnaflow's Troy. 6" body Cat as well. Worth thinking about - at least you know exactly what you're getting.
I'm a jdm fan to my detriment with some of the parts I buy... Incliding exhaust's for the most part.
But for the money, I'd carefully consider custom Ti pipe work (Appropriate grade Ti mandrel bends can be purchased in the US) with slip jointed 'Burns Stainless' center resonator/s and a brand name rear can.
The thin wall stainless pipe work 'Burns Stainless' stock are only a poofteenth heavier than the same size Ti
Cheers
Justin
But for the money, I'd carefully consider custom Ti pipe work (Appropriate grade Ti mandrel bends can be purchased in the US) with slip jointed 'XXXX Stainless' center resonator/s and a brand name rear can.
The thin wall stainless pipe work 'XXXX Stainless' stock are only a poofteenth heavier than the same size Ti
Cheers
Justin
Don't go posting this stuff up on SAU. The real good gear you need to keep quiet and to yourself :) I did an exhaust with a friend years ago when I lived in Sydney and had after hours work to my old employers factory, tools etc. Their gear is top notch and I was planning on using two of their real mufflers in a twin system.
What I need to find is a centre muffler that has a 4" inlet and twin 2.5" outlet
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
    • Well the articals keep saying a Q50s (Skyline in Japan) with a new Manual gearbox. I like the talk about the new looks with the round tail lights. I hope they bring back the retro look like they did with the Z
    • Off the back of feedback we have decided to mix up this next Motorkhana at Avalon to have some targeted skills practice for beginners to advanced. Saturday 6th September 2025 8:30am Capped 26 entries Standard Entry Fee: $89 Members Entry Fee: $55 (SAU Victoria Only) Entries Close: Friday 5th February  Where: 55 beach road Avalon. https://maps.app.goo.gl/HNUE3EuNue3sJxh38 Entries: Limited to 26 entrants (Passengers allowed over the age of 14 with a signed disclaimer and same safety gear) Disclaimer: Download  Please electronically sign and email to [email protected] or print and hand in and Driver Sign In. To compete in this event you will require A valid  AASA General Speed licence or (Day license via the AASA Website for $50) MA Licenses are no longer accepted by AASA https://aasa.com.au/  A helmet, long sleeve clothing and a 1KG mounted fire extinguisher recommended (But not Mandatory). Further details within Supp Regs on the enty link. Entry Link > https://www.sauvic.com.au/entry/deca/20250906 You can bring and have a passenger in the car but they need to comply to the same safety and clothing as driver. Bring your car and get to battle others, win, lose or draw. I can guarantee you will have lots of fun. Any questions email [email protected] Entry List:
    • Wanna rewrite all of that in, say, 2 or 3 separate sentences, so that we can read it?
