What about Hankook Z221's, not the two groove ones. Only available in 17 and 18" but three compounds listed. For sprints I'd be tempted to try the softs.
Neil used them on the weekend at Bathurst and found they worked better than the Avon softs (that cost $200ea more). There's a reason they were banned from superlap
I thought Neil's Avon's were supposed to be the best thing since sliced bread with their special break in process.
If Neil is happy with the Hankook offering compared to the Avon's then they would be a great tyre for the money considering that they are hundreds of dollars cheaper each.
Go back to page 18 and read my post about them. Cliffs: Great when new, but the soft compound only last a handful of track days. Admittedly, I am hard on tyres, and the car is no featherweight...
Edited by hrd-hr30
If yours were softs then on your heavyweight and in hot weather that's asking a bit much don't you think Harry? I was thinking mediums for mine which is several 100kg lighter, something like 255 rear, 235 front tyres.
Richard: "For sprints I'd be tempted to try the softs"
Harry: softs don't last long
Richard: "softs were asking a bit much don't you think Harry... I was thinking mediums..."
Harry: :/ uh, glad I could help?
lol Yes Harry, instead of waffing around I should have come right out with it and said that the Hankook softs on your unsophisticated heavyweight very likely overheated and so were cactus from then on which was hardly the tyres fault. For me, being tempted to use softs is a bit different to thinking mediums which obviously is the safer option.
The hottest conditions I used them in was at Morgan Park at about 34degrees ambient. They showed no signs of overheating on the day - grip never dropped off like it would if they got too hot, and they still went well at a hillclimb and Phillip Island after that, so I don't think "they overheated and were cactus from then on".
There is no chance the hillclimb overheated them. It was nice and cool at Phillip Island and they were great down there too. Not only did grip not drop off in any session as it would if they got too hot, but I did my best lap on the last lap of the day. Next time I used them they were instantly horrible and got worse with each lap. They just lived their life-span of heat cycles if you ask me.
lol at someone running pogo stick and horrible multi-link rear suspension calling the Soarer's double wishbones unsophisticated!
Edited by hrd-hr30
Double wishbone suspension eh, like the old Holdens used to have up front. You are on a winner there Harry :no:
Anyway tyres. MP, depending on which circuit, can be a bit hard on tyres, all those sharp corners. And I have no idea if overheated tyres go off straight away or just can have their life shortened. Must check that out.
  • 3 weeks later...
Semi related (pun) to this thread – what would you guys recommend running for a hill climb?
I've signed up for the Haunted Hills intro next month and have the following options:
  • Street rims: Kumho KU36 (UTQC 180)
  • Track rims: Toyo R888R (UTQC 100)
I'm guessing it might be hard to get enough heat into the Toyos to be effective on short runs...?
  • 5 weeks later...
As an experienced hillclimber, the semi (even the R888) will always be better than the KU36.
Thanks for the tip Harry, exactly what I did.
I'm really liking the R888R, even in my skinny 225/45ZR17 square setup. Very communicative and plenty of warning before they let go, in a progressive way.
I'm new to semis so can only compare to street tyres, but still definitely recommended.
yep, that's where I found them. My set arrived today. 265/35 R18 for the Soarer, so it will be a direct comparison vs:
245/40 Nitto NT01 - 1:01.3 Lakeside
235/40 Hankook Z221 - 0:59.8 Lakeside
Edited by hrd-hr30
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
