S A U N S W - Texi, "the Original" @ Sutton Road
  • Replies 219
I've never really been one for skids n stuff. Dunno why just dosent really appeal to me
...............(waits for flaming)
Always been more interested in going quick point to point, problem is I don't seem to be able to get fast launches right so I take of like a granny in a carolla. I need help me thinks
Is there a certain type or size of fire extinguisher we need? I'm unsure what a ' insurance approved fire extinguisher ' is, my friend and I both have to buy one - don't want to get one that isn't approved.
Cheers.
Edited by sweefu
they only really come in 1 size from places like supercheap auto, autobarn, bursons etc..
It will have a metal bracket (not plastic) and have a stamp on the box saying "CAMS certified" or "CAMS approved"
I picked mine up from supercheap for about $30 from the 'outdoor' section with camping crap
It's exactly like belting through National Park. Exactly
cheers N1 and Duncan, thats some scary stuff, too many track days has weirdly made me even more careful through those sections than i ever was pre-trackday..i guess it was knowing how easy it is to lose it and wipe out that made me never look at nasho/old pac runs the same way again. Still i dont plan on missing this thing and will give it my all on the day..well 8/10ths anyway.
Yep that is all you need to do at a place like this, and it really is no different to a tarmac rally. You just choose what you think is a safe pace - if you think 110% like you might on a track, it can be dangerous or expensive.
But if you keep some in reserve and show respect to the track and conditions it is fine.
There are very few places in NSW where you can head along a 1 lane road at any speed you like, no worries abiout speed cameras....so don't miss this!
f**k it, this place is too much fun.
I'm going to get the race car going for this.
Packing spare bearings? :P
Remember, I won't be there to make changes or check tyre pressures for you... :P
Thanks for that, I think I know what to get.
http://www.camsmanual.com.au/pdf/10_gen_req/GQ09_Schedule_H_2012-2.pdf
:D
Trying to coax the missus to bring and drive the starlet.
And trying to convince her friend to come and run her mps3.
I'm trying guys, really I am.
hey why not....Rosie has brought her mazda 3 to a few events, and a starlet finished in the top 5 the first time we ran down there ;)
Indeed, bring the missus and her friend along. This event has actually been almost won by someone in a stock (but stripped) Starlet, but that's because Reece was driving!
And yep, that's my little sister Duncan's talking about. We both did a day at Oran Park way back when - I know I'm not the only one who misses that track... We were in separate groups, and she told me later that she'd spun the Mazda3 and went off backwards at Shell Corner, but she shook it off, waited for the rest of the cars in her group to go by, then got right back into it! With a bit of tuition from Duncan, she built some confidence and really enjoyed the experience.
Oh, and that map just happens to be linked to an article about Chubbs: http://chicanecultur...dney-australia/
And yep, that's my little sister Duncan's talking about. We both did a day at Oran Park way back when - I know I'm not the only one who misses that track... We were in separate groups, and she told me later that she'd spun the Mazda3 and went off backwards at Shell Corner, but she shook it off, waited for the rest of the cars in her group to go by, then got right back into it! With a bit of tuition from Duncan, she built some confidence and really enjoyed the experience. Unfortunately, there isn't anywhere near as much run-off room at the Sutton Road Complex, so have fun, but be wary of your surrounds and be careful!
A couple of weeks ago Aldi had recently dated 1kg fire extinguishers with the double metal bracket for $15ea. Have a look at your local Aldi before trying supercheap/bunnings etc.
Also make sure you get one that's recent, or it wont be any good for cams events if you want to enter any later.
Please do enter the starlet, need micra vs. starlet battle :D
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
