hey guys.. i have a 32gtst and recently bought a 32GTR half cut.. i got this week off work 2 do the conversion, im a 3rd yr apprentice mechanic and i convinced the boss to lend me a hoist bay in the work shop for a week.. does any 1 know if there any bits and pieces i will need that are not on a half cut that i will need 2 buy. i already have a new fuel pump and a new sump for 2WD and splashed out on a tomei oil pump :D.. does any 1 know of any common problems i will run in to along the way.. if any 1 knows of problems a heads up would be good so i dont find my self waiting around for parts
https://www.sau.com.au/forums/topic/396526-rb26-conversion/
What's the colour? How many Km's?
Were you the first owner?
If your not willing to post pics don't expect to sell it fast.
Pretty sure he's not trying to sell it mate or it would be posted in the for sale section not the forced induction section asking for advice...
https://www.sau.com.au/forums/topic/396526-rb26-conversion/#findComment-6298476
once he finds out the expense of the band-aids, screw drivers, duct tape, deodorant and WD-40
he'll be compelled to sell.
https://www.sau.com.au/forums/topic/396526-rb26-conversion/#findComment-6298932
I have just finished my R32 Rb26 into R33 gtst, was good fun, lots of tears and didnt have the convenience of a half cut. I had to use Rb25 engine mounting brackets, might need those not sure if they are compatible with xmember? I know a guy in brissy who did my loom, send it to him he sends back modified to work, he is good and cheap BH_SLO32 on here. I definately agree with the above crank collar or atleast a new oil pump and check the collar. I just rebuilt.
https://www.sau.com.au/forums/topic/396526-rb26-conversion/#findComment-6301822
I'm doing a simular thing tho into a BMW I just changed the head gasket and re dis water pump just a general maiternance service I didn't bother with oil pump and it all looks good but I had the luck to see motor running before being removed. A new set of bearings wouldn't hurt either
https://www.sau.com.au/forums/topic/396526-rb26-conversion/#findComment-6301874
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
