I agree, turn down the wick mate and enjoy...besides, your car is stupidly or cn I say dangerously powerful
slap stocker box in
adjust wastegates to 17pis
enjoy for a long time without issues
will save you 7k
downside is less blokes on here humping your leg due to awesome output
It's at 25 psi man. Hardly "screwing its brains out" and realistically I haven't run over 22 psi at all which is less than what most people run on -5's. if I turn it down I may aswell drop back a turbo size. There are associated costs with doing that too.
sorry to hear bout the box :(
interesting though, with E85 and new turbo tech, starting to really push the boundaries of what street cars would normally have to contend with. Maybe you'll create a market for a street-able bullet proof gearbox option - but you've unwittingly created a bit of a "ceiling" for what people might be considering build wise as well... (With respects to gearboxes)
not sure if it's of much help, but i recently found out i have 33 v-spec ratio diffs (like a god damn kinder surprise this car) soooo... i have a getrag and 33 diffs... if you're in melb anytime soon, you're welcome to take it for a drive if you like, see what you think. She might be a bit slow for you, but she goes alright :D
Torque ratings ain't high enough. Try again lol
Phone them. I bet higher ratings are available.
If you had a high reving 2.6 with less torque, this wouldn't be a problem.
Edited by black bnr32
I believe he is in Vic ATM for DECA this weekend, what revs does it sit on at 110
go on Paulie get the OS88, you know deep down you want it, and then I can take it for a drive and see if I want one :P
What timing! I'm actually in Melbourne right now! Thanks for the offer Dan. Flick me your number so we can organise something. That would be fantastic. I've always wanted to launch a Nur spec from 10,000 RPM :P
What a great clip.
that thing is an animal!
Is it just me or does the gear changing sound slow for a sequential box? I don't know much about them so maybe there is a setting for gear change delay.
may the sequential be with you... always
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
