I agree, turn down the wick mate and enjoy...besides, your car is stupidly or cn I say dangerously powerful
slap stocker box in
adjust wastegates to 17pis
enjoy for a long time without issues
will save you 7k
downside is less blokes on here humping your leg due to awesome output
It's at 25 psi man. Hardly "screwing its brains out" and realistically I haven't run over 22 psi at all which is less than what most people run on -5's. if I turn it down I may aswell drop back a turbo size. There are associated costs with doing that too.
sorry to hear bout the box :(
interesting though, with E85 and new turbo tech, starting to really push the boundaries of what street cars would normally have to contend with. Maybe you'll create a market for a street-able bullet proof gearbox option - but you've unwittingly created a bit of a "ceiling" for what people might be considering build wise as well... (With respects to gearboxes)
not sure if it's of much help, but i recently found out i have 33 v-spec ratio diffs (like a god damn kinder surprise this car) soooo... i have a getrag and 33 diffs... if you're in melb anytime soon, you're welcome to take it for a drive if you like, see what you think. She might be a bit slow for you, but she goes alright :D
Torque ratings ain't high enough. Try again lol
Phone them. I bet higher ratings are available.
If you had a high reving 2.6 with less torque, this wouldn't be a problem.
Edited by black bnr32
I believe he is in Vic ATM for DECA this weekend, what revs does it sit on at 110
go on Paulie get the OS88, you know deep down you want it, and then I can take it for a drive and see if I want one :P
What timing! I'm actually in Melbourne right now! Thanks for the offer Dan. Flick me your number so we can organise something. That would be fantastic. I've always wanted to launch a Nur spec from 10,000 RPM :P
What a great clip.
that thing is an animal!
Is it just me or does the gear changing sound slow for a sequential box? I don't know much about them so maybe there is a setting for gear change delay.
may the sequential be with you... always
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
