14 minutes ago, Piggaz said:
Well, guys get all excited about a billet wheel being lighter.... but most of the weight is in the turbine wheel. The efr wheel is half the weight of a normal inconel wheel.
Removal of all the small piping and super tight bends of the intake and exhaust. Just look at it all, it's hardly designed for MASS airflow. Put a pressure sensor on the intake of a 450 kw gtr and I bet it's pulling bulk vacuum. Dyson would be impressed.
Haha, Piglets rebuild of his busted Dyson :D
34 minutes ago, ActionDan said:
I wonder why BMW went with all the hassle of twins on a straight 6 motor instead of a slightly larger single?
I guess they wanted to make it laggier. I mean, 1400 rpm is pretty shit response - A single would be on idle for sure.
I bet a cheeseburger that their packaging is not a spitting image of the RB26 configuration.  A huge amount of my argument against low mount twins in a GTR when any kind of flow is needed has to do with the packaging.
Edited by Lithium
Yep 100% you can't get a bigger exhaust housing on to those stock manifolds and the rear intake in rubbish.
Would like to see some low mounted EFR's on customer manifolds.
"When any kind of flow is needed" means different things to different people.
I think you guys need to go back and read some of your own posts from 10yrs ago on here and see how you were reacting to 300-350rwkw back in the day.
For those power levels, even today, twins are fine for a mildly driven street car. Does that mean there are not better solutions? Of course not, it's been a decade of tech advancement, but the argument seems to boil down to "did you know that if you spend more time and money you will get a better result?!".
No shit lol
Edited by ActionDan
  • Like 1
Artec do a 0.85 T28 ass.
4 hours ago, Lithium said:
9180 would do for now :D
Hows that build of yours going?
Sick f**king work Piggy, looking forward to seeing the final result - but you're already smashing it. Can't wait for the data, and for you to finally be able to get out there and do awesome shit with it.  I remember the OTP discussion we had back in 2013 where you were challenging me to think of any RB setup with response and power like your own, bet you wouldn't have expected your own car to end up with a single turbo on the exact same engine and as a result stand up harder earlier than it ever did before? :D
f**king kudos to having the Insight involved to get a great thing even better.
Honorary mention gotta go to the drunken conversations with the Wild the sphincter of the universe Rare Breed.
* This post sponsored by the SAU language filter
Slowly getting there. Wiring was completed last week so a little more fab then it can get some fluids and a tune :)
  • Like 1
I'm curious what spark plug gaps you are running with the Godzilla motorsport kit?
I might need new coilpacks and was thinking this kit over the conventional splitfires.
In the search your the only guy i saw that runs the Godzilla R35 billet coil pack kit, so curious on your opinion on why you went these over spitfires.
I'll have to get back to you on that. Some plug that Scott uses. It's a heat range 9 with a funny tip. I thought I took a photo but I can't find it.
Actually i just saw this in a comments Facebook section of the Godzilla Motorsport page which to me was interesting.
So i spose its just for cars to run high power reliably without a breakdown in spark. Rather than what i thought of larger gap better bang/performance
Bruce Sullivan What plug gap can you run with these ? Can you get away with 1.1 for around the 450AWKW's ?
Cheers
LikeShow more reactions
 · Reply · May 28, 2016 at 7:43pm
Remove
Godzilla Motorsport
Godzilla Motorsport No turbo engine should ever run 1.1mm gap . That is only for na engines
 · Reply · May 30, 2016 at 5:52pm
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
