Set of Super Advan wheels black centres with blue outers.
17x8 35p with 225/45R17 nankangs with 75% tread
17x9 38p with 245/40R17 nankangs with 75% tread on the outside and 1% tread on the inside ;)
Open to offers or swap for a set of R32 GTR wheels. Located southside 0435 626 691
Just realised that I still have the low km's stock turbos off my GTR sitting in the shed.
They're in good nick, will let them go for a neat 100 bucks just to reclaim some scarce shelf space.
Do the PM thing if interested.
Got some EOIs to put up, figure might as well use this thread:
Samsung 24" FULL HD (1920x1080 resolution) LED PC monitor. As new condition, only about a year old anyway. Absolutely nothing wrong with it whatsoever. Very impressive monitor for something 'ordinary'. Has HDMI input.
$125 or best offer, will come with whatever cables you require with it (power, VGA/DVI, HDMI).
Dell 22" FULL HD (1920x1080 resolution) LCD PC monitor. Also as new condition, however it's a bit older than the Samsung. Absolutely nothing wrong with this monitor either, and picture quality/response etc is very good also.
$75 or best offer, will also come with whatever cables you require. Doesn't come with HDMI input though.
Both of these monitors are currently set up in my room and can be viewed in person should you desire. Reason for EOI sale is I'm looking at spending a ludicrous amount of money on a 46" LED TV to replace them with hahahaha
I'm also happy to set the monitors up for you should you require the assistance.
Let me see if I can find out for certain. I am after some for my car. Were these lower than stock hieght?
If they will fit my car I will grab them.
Not sure if they were lower than stock height. They came with the car so nothing to compare it too. Ill see if I can dig up some pics of when I bought it. May give u an idea? Ill measure them as we'll and post tonight.
fronts are 48cm
rears are 74.5cm
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
