Got some R33 parts for sale....
NISMO R33 RB25DET Front Exhaust Pipe. Comes with Dump Pipe and O2 Sensor - $150
Series 1 R33 4 Door Rear Tail Lights. Excellent condition, not a mark on them - $300 (pair)
R33 Polished Wiper Arms - $30
On 12/9/2017 at 5:42 PM, vkadam said:
imageproxy.php?img=&key=4b1e78680f916b86
R34 GTT parts
Stock suspension $100
stock cams $150
Stock front brakes $350
Tuneagent manifold suit topmount 3076R $150
R34 radiator overflow $10
vkadam,
I'm interested in the stock suspension if you still got it. Let me know. Cheers, Luke. :)
  • 3 months later...
  • 11 months later...
  • 1 month later...
Hey got an RB26 manifold to sell, $800 which is a huge discount for an as-new tubular steampipe and heat coated manifold
MTX racing, heat coated, Split flange T4 with merge collector, High quality bit of gear
Only test fitted
Reason for sale is that it didn't sit the GTX4022R low enough in the engine bay for my RB26/30 to clear in my r32
It's a good bit of gear and if you are in Canberra, happy to come around and test fit it with you if you have the hot side stripped out
If you want pics please send an SMS to zero four 15 eight 38 790
Will try and upload pics but if you just text me I'll send pics, I live in Curtin.
Cheers
Andrew
Edited by dorifticon
  • 3 weeks later...
Hey all,
Have a bunch of aftermarket parts from my 32GTR, in preparation for it’s rotisserie respray:
Full 3.5inch turbo back exhaust. Not sure of brand, but great note and I think the section from cat to extractors is titanium (not 100% sure, though): $500
HKS fully adjustable coil overs (pics coming soon, just need to give them a clean): $750
2 x Garrett ball bearing 2860-5’s in near new condition (only a few thousand km’s): $900 each.
Complete R32GTR Brakes (non-brembo), including slotted rotors (DBA, apparently): $500 per pair
Koyorad Radiator: $400 (retails for $690) and only a few thousand km’s old.
ABS Module and mount: $300
Also have a bunch of other parts, so if you’re after something specific, let me know and I’ll see if I have it.
Welcome to view anytime. Parts located in Red Hill.
  • 2 months later...
  • 7 months later...
I have a couple of 2530s from my R32 from over ten years ago. I'm sure they need a rebuild and have no idea if they're worth anything but didn't have the heart to throw them out. I know the actuators used to be worth a bit on their own, best offer over a coffee? Anyone want them? Located in Kingston.
  • 3 weeks later...
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
