Not really Nismo but close enough but I had a no: 65 of the original first run GT500 "RRR" Block but its been recently sold and it's on a boat to Oz and will soon be with new owner.
Concensus = Terry, Chef man, and Marcus all not cool!
Have a few bits, but recently went looking for a genuine sticker like this one pictured As a replacement for mine on my boot lid in case i ever respray it (couple of little marks), and found them on yahoo JP for $80! One i saw had a price tag over $150!!
Oo old NISMO fetching a bit aye.
Really Ash? I had the full kit in a V35, including sway bars, and it was one of the best I've ever used. Of course the V35 was purely a street car with a few track days for good measure. But loved the ride in it and did all right at the track as well
I thought the Nismo Super GT Cars all used RRR Blocks..?
Hence it is a Nismo item...
Oh No Simon!
Surely not this one that my OCD took off your car on Sunday whilst you were out?
Don't worry! I put a rag in the hole!
I'd feel guilty otherwise...
Actually there's another recent version isn't there - looking somewhat like a - I dunno - a hub cap???
That black centred one of Richard looks you beaut tho'
That matches my radiator cap, do want....
More Nismo-Nuts on these last two pages...
I think "NISMO" could probably sell his User Name for a price ;)
I have an old-style Nismo Badge Luke that you're welcome to pick up. New too - but attached to a board!
If Luke doesn't want it, someone else can have it.
Meanwhile,...
...for an extra 15% air flow
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
