Not really Nismo but close enough but I had a no: 65 of the original first run GT500 "RRR" Block but its been recently sold and it's on a boat to Oz and will soon be with new owner.
Concensus = Terry, Chef man, and Marcus all not cool!
Have a few bits, but recently went looking for a genuine sticker like this one pictured As a replacement for mine on my boot lid in case i ever respray it (couple of little marks), and found them on yahoo JP for $80! One i saw had a price tag over $150!!
Oo old NISMO fetching a bit aye.
Really Ash? I had the full kit in a V35, including sway bars, and it was one of the best I've ever used. Of course the V35 was purely a street car with a few track days for good measure. But loved the ride in it and did all right at the track as well
I thought the Nismo Super GT Cars all used RRR Blocks..?
Hence it is a Nismo item...
Oh No Simon!
Surely not this one that my OCD took off your car on Sunday whilst you were out?
Don't worry! I put a rag in the hole!
I'd feel guilty otherwise...
Actually there's another recent version isn't there - looking somewhat like a - I dunno - a hub cap???
That black centred one of Richard looks you beaut tho'
That matches my radiator cap, do want....
More Nismo-Nuts on these last two pages...
I think "NISMO" could probably sell his User Name for a price ;)
I have an old-style Nismo Badge Luke that you're welcome to pick up. New too - but attached to a board!
If Luke doesn't want it, someone else can have it.
Meanwhile,...
...for an extra 15% air flow
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
