Id say that I would compete for the title of "biggest Nismo whore" in this thread, Simon can probably confirm haha
My recently acquired Vspec R34 has the following;
ENGINE
35]
NISMO OIL - AIR SEPARATOR
35]
NISMO REINFORCED TIMING BELT
35]
NISMO INTAKE PIPING
35]
NISMO INTERCOOLER
35]
NISMO INTERCOOLER PIPING
35]
NISMO ENGINE OIL COOLER
35]
NISMO ADJUSTABLE FUEL PRESSURE REGULATOR
35]
NISMO HI-FLOW FUEL PUMP
35]
NISMO IRIDIUM SPARK PLUGS
35]
NISMO RACING RADIATOR CAP
35]
NISMO R-TUNE AIR CLEANER DUCT
35]
NISMO OIL FILLER CAP
DRIVELINE / CHASSIS
  • NISMO G-ATTACK COIL OVER SUSPENSION
  • NISMO SUPERCOPPERMIX COMPETITION TWIN PLATE CLUTCH
  • NISMO FRONT AND REAR SWAYBARS
  • NISMO LONG HUB BOLTS
  • NISMO R-TUNE BRAKE PADS FRONT & REAR
INTERIOR / EXTERIOR
  • NISMO R-TUNE FRONT BUMPER
  • NISMO CARBON LOOK CENTRE PILLAR TRIM
  • NISMO CLEAR FRONT INDICATORS
  • NISMO CLEAR SIDE INDICATORS
  • NISMO “GT500” L.E.D TAIL LAMPS
  • NISMO GEAR KNOB
  • NISMO FLOOR MAT SET
  • NISMO METER SET – WHITE
  • NISMO M.F.D ( MULTI-FUNCTION DISPLAY) SPEC KIT VER.II
Plus, do the plates count? lol
And my daily R33 has;
Nismo LMGT-4's
Nismo Braided brake lines
Nismo Clutch slave cylinder
Nismo Super Coppermix single
Nismo radiator cap
That is cheating Joe.
You can't buy a Nismo promo car and claim nismo whorisim.
hahaha
Bahahaha sure I can, I would have had a list that long on the 33 if I had thrown the cash at that instead :yes:
Plus I harass you to sell me those rims EVERY time I see you lol
Nismo...
LM-GT4 wheels
Clear indicators (I think they are Nismo?)
600cc injectors
Competition Spec Coppermix twin plate clutch (awesome clutch thanks to Stevo-O).
Oil separator can
Fuel pump.
Fuel regulator... and
'Hoodie' jumper
Omori factory shirt :-)
nismo lmgt4
nismo dark indicators
nismo exhaust
nismo cluster
nismo floor mats
nismo ti gearknob
nismo fuel pump
nismo power brace
nismo timing belt
.......how is it all?....GREAT, except the exhaust which looks like a55 (and not the good kind)
still yum ^^
...and the thing about Nismo items (except for your exhaust if it has a 90 degree bend in it), is that you can take them off > sell them easily
Terry I put the exhaust up for sale with some other bits and pieces last week. Many expressions of interest for everything and few pieces sold, but the exhaust :/ Its the discontinued oval-tipped one...The guys over on the UK forums were selling them used for $1400 :O
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
    • Just like in being 14mm too small (296mm) makes it not fit, being 14mm too big (324mm) it also won't fit. You want to find the correct rotor.
    • @GTSBoy Ok so that was the shops problem...they showed R33 rotors on R34 page and i did not know 296 do not fit(and are for R33) Yes i bought "kit" with rotors and pads. Pads are ok(i have GTT calipers front and rear). They have some 324mm but no 310mm. So i dont know if they would fit. I have 17inch LMGT4s So another question. Can i fit those in the rear or they are just "too" big for that?
    • I started removing the tank a while back with the intent to give it a proper clean. Got to a bolt that I couldn't undo completely due to a diff being in the way, so just said f**k it and siphoned the gluggy old fuel out and called it a day. Looking it the tank it looks less corroded than the one in the pics for that billet hanger from Frenchy's anyway. Isn't it the fuel filters job to worry about this stuff? I scraped off most the crusty shit of the hanger but will give it another go before reinstall coz maybe the fuel and return pipes are also full of gunk
    • Pretty sure it is a common fault. I believe this is the only part you need, but don't quote me as I don't have a V36.  I also believe it is a bit of a pain to change and the device needs to be encoded to the car once it is replaced, so may need someone with the right tools. Buy Genuine Nissan 48700JF00D (48700-JF00D) Lock Set-Steering. Prices, fast shipping, photos, weight - Amayama
