Has anyone used two oil sandwich plates before (on top of the stock oil warmer / cooler) and has it caused any clearance issues with the fitment of the oil filter? My skyline is in a million pieces (engine out) at the moment so I can't have a look and estimate the clearance.
I know it's not ideal using two as its just another point of failure / leaks, but it will make my life easier :P
Cheers
Justin
https://www.sau.com.au/forums/topic/402155-using-two-oil-sandwich-plates/
No I mean two sandwich plates in addition to the stock oil warmer / cooler. I have an oil cooler to install with a built in thermostat in the sandwich plate, so it doesn't have room for the 1/8" NPT sensor holes. I need to install an oil pressure sensor and will possibly install another oil temp sensor down the track so i will need a second sandwich plate with the sensor holes.
I realise I could get rid of the factory oil pressure sensor and install the new one there, but then I would need to find a BPT to NPT adapter to fit it, and the (crap) factory oil pressure gauge would stop working, which whilst pretty much useless would annoy me to not have it working. I think you can get a BPT adapter with a tap for both a BPT and NPT sensor, but I havent been able to find one anywhere.
Ok, most common thing to do is get a relocator kit. Then the oil filter relo plate has the bungs u require
That is the third and probably smartest option :) - but if I did want to do go with the 2 sandwich plates do you think I would have a clearance issue between the oil filter and the drivers side wheel arch? As my engine in not in the car I cant visualise it.
I am just looking the oil filter now and I do use the smaller R34 type ones, so I am pretty sure there will be plenty of room.
Can't you just drill and tap some holes in the thermo sandwich plate?
I thought of that but there is only a small area where that might be possible, and its kinda recessed and on an angle:
http://www.racerpartswholesale.com/product/1597/Mocal_Sandwich_Plate
Not sure it how well it would work.
I use two on my boat.
one for oil supply from dry sump + sensors
one mocal sandwich plate for thermostat - attached to heat exchanger
No dramas in terms of "its just another point of failure / leaks"
Not sure on clearance issues tho...
Using an RB25 in a boat = awesome! :P
I'm going to order one of the Just Jap items linked to above, I think clearance will be fine.
Thanks everybody.
  • 3 years later...
Hi all, I've just ordered a Driftworks oil cooler kit with the Mocal thermostatic sandwich plate, which doesn't have sensor points.
I have an existing sandwich plate for Defi sensors and I'm wondering if I can run both at the same time? The car is an R34 GTT with the Neo engine and standard small Ryco Z422 filter.
The other option is to add an extender piece (?) between the oil cooler sandwich plate and the braided line where you can hook the sensors but I'm not sure if such a part exists?
1/8 npt into 1/8 bpt won't seal?
NOPE
the threads are incompatible, but they are close enough that you can force it in. however that means you have over stressed some of the threads and it could develop a leak at any time. Which is probably a bad idea if you use it where you care about the quality of the seal, for example.. in a pressurised oil feed!
to answer the original question, in a GTT I don't see how clearance could be an issue. I reckon you could stack 5 or 6 sandwich plates before you have any issues.. there's a ton of room!
  • Like 1
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
