Do you mean the pulley's are not at the correct offset for the pump?
Or the V grooves have incorrect angles, or are to shallow or deep?
More info please.
The offset was off using a 25 pump and bracket on a 30.
Oh so you mean you used a balancer that is designed as a factory fitment but put it in an application that it was unintended for?
Is anyone having a problem with a 25 balancer on an RB25 or a 26 balancer on an RB26?
I'm having a problem using a 26 balancer with 26 power steerin pump and bracket on a 2630. Bear in mind this problem did not exist when using the ATI. Mark Berry had same problem.
Piggaz also was having same issue which I think was 33 balancer on RB26 (2.8) with correct power steering pump etc. No prob prior to fitment either. Correct Paul?
I was having a few issues with this flicking off PS belt thingo. We made sure everything was "square", IE the PS pump/bracket was spot on and I also fitted the idler pulley thing for the belt. Problem went away. Car will be back on the road soon so I'll be able to report back.
If the pulley is underdriven u need a smaller belt. Even my ATI spat a belt. I put a smaller belt on one that only just went on with ps fully loosened off and no probes now. try get as close to the crank as u can that's what I think.
They're the same size as standard.
Were you using a 25 balancer or a 30 balancer?
I believe it was a 30 one.
But don't quote me on that.
I was pissed it happened, BUT, these things happen when you are using different parts from 3 different engines, I like to call it teething problems.
I'm using a ross rb25 balancer with rb25 pump with their idler pulley kit and aligning the pump as per Ross's instructions and still throwing belts. it was never a problem before the new balancer so there must be something going on
Get a straight edge and run it from the balancer to the PS, I found the difference to be about 5mm, we drilled out the bracket so the whole PS assembly could move forward 5mm, the job took a couple of hours to do but now the 2 pulleys align perfectly.
And it was only the PS that was causing issues, the AC and ALT are fine.
Give ROSS a call and see what they say, its a common problem, albeit a easy fix if you modify the bracket.
Something is really wrong if your throwing belts with the idler pulley kit...
More elaboration, I can confirm that on the track I failed to spit the powersteering belt again. Mine is rb25, limiter 7700, to recap on the mods I did to help, I machined front lip of p/s section down to 1mm over belt height, and beadblasted all the anodising off the belt grooves, and refitted using a new gates racing belt. Time will tell if its a confirmed win
That's good news Amon.
I asked Ross some months back if he thought it could be the coating - as he insisted there was no difference (measured up) between the ATI and the ROSS. I wonder if perhaps the anodising is somehow making it "grip up" ?
Mine already had been machined down from Ross - this is something they had already struck apparently. Interesting that yours which I assume is not as old as mine, still had the lip...
Yeah iv only had mine since the start of this thread. could of been old stock... I recon the anodising makes the belt intermittantly slip and grab and create a flicking of the belt. Might be wrong. whereas the blasted pulley is very grippy and consistent
I am coming down to the nit and gritty part of my build, and saving the power steering belt issue for last. I have run a dry sump oil system on my RB26/30 build and I cannot risk having this issue, so I am going to correct/fix the issue first, before it even becomes a problem. (save the "If it ain't broke, don't fix it" comments please). I don't want to have a catastrophic engine failure due to an f**king power steering belt.
I am running my 2 year old RB26 Ross Dampener on my RB26/30 build, don't see a problem using it. I am either looking into the Ross Idler Kit, or this other kit they have.
http://blog.rossperformanceparts.com/category/engine-protection-kits/nissan-rb26/
Anyone running a dry sump have experience with this type of set-up? Anyone see any issues running this kit? Any input would be greatly appreciated.....
If not, then just to avoid the whole issue, I am gonna run a Volvo Electric Power steering pump.......
I've done a couple of HTD driven steering pumps with Ross
Never had a single drama with them. Slows the steering pump to 50% (or whatever speed you choose to gear it) perfect drive and never had a belt come off. After we fitted the first kit and made some recommendations to Ross I believe he has refined the setup and is supplying some specific fittings and spacers that are needed now.
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
