I'm not sure the Haltech can do that. They can't do aftermarket trigger input from a hall effect sensor in their 'Pro' model or closed loop boost control over wheel speed so I'm pretty sure they wouldn't be able to handle something like that? Can anyone confirm?
I run PS2000 with full flex etc.... Haltech said it can't be done, JEM said it can and proved it :)
I am running Power FC with Data logit...f**k the massive expense of all the hardware, tuning etc with the systems explained above. For me this arrangement is fine as I drive like an old lady on the street and leave the full load, boost stuff for the track so pretty easy to manage the fuel side of things...95 on the street and E85 for the track
zackery
Also, the difference between 85% and 70% doesn't necessarily effect the octane rating as they can/do use other additives - not just 30% 91RON + 70% Ethanol
If your initial tune is done on 85%, even if you put E70 in, it's only going to run slightly richer....and depending on your tuner, that can be a good thing
zackery
thats what i wanna hear ... bring it on .. looking forward to getting an E flex tune...
Edited by SliverS2
Daniel by way of comparison between a pump 98 tune vs E85, what is a typical full-load target AFR? And what is a typical cruise/low load target AFR?
Also interested to get a handle on fuel system delivery requirements for sizing. ie. for a given power target what is the rule of thumb for injector sizing + pump(s) vs running on pump 98?
Rough sizing requirements on methanol were to expect double the fuel usage over avgas. The calorific content per unit of mass in those fuels is a factor of two so easy enough to understand. I would imagine the maths for ethanol would be roughly similar.
Ok so what were the target numbers to chase?
Appears that as a blended fuel the calorific content is bumped up a fair whack from straight alcohol. 30% differential at max power should see an 044 pump cope with 300-330rwkW worth of fuel delivery.
FYI, Eltham United is listed as having E85 on the United website, but they do not and will not. They dug up the forecourt to install the pumps and line then figured out they have fibreglass tanks. So no E85, ever, at Eltham :( that's dinted my E85 ambitions and made a setup which can handle both 98 and 85 a must.
Whats wring with fibreglass tanks? All new caltex sites are getting fibreglass tanks to replace the old steelies
Not every one is sensible like Roy the old lady. Kids these days
yes the simple things in life are often the best..but that said somebody has to pioneer the new ideas..
Any dope can build a 300kw skyline these days its a no brainer cause its all been done before..
Trying and testing new things is what sets you apart from the rest and in a few years everybody will be running E-sensors and flex fuel and wondering why we ever did it any different..What is needed now is an ecu smart enough to know how much to adjust the tune without the need for the tuner to make multiple maps..My setup shows it needn't be overly expensive. I have spent barely 2 grand all up, thats as much as a new PFC was back in the day and as today's ecus get cheaper 2nd hand more and more people will adapt to the new tech..I believe atm the only thing really holding alot of people back is the need for so much dyno time to set the multiple tunes up..but most of us end up back at the tuner every 6 months anyway cause we change something or other so why not setup for it now and it won't be too long before you have enough tunes in your log to make a decent enough coverage for flex fuel..There will always be dinosaurs like Roy showing us how it used be done and that's good..Cause dinosaurs are cool. :D
Yes sets us apart cause we are broke ass mutha's for being the pioneers :)
AFR can vary between two engines. I am not a tuner - Sean at EFI Performance (07 3801 8075) does all our tuning and we always use a combination of AFR and EGT sensors. One engine can be 750-800 degrees at 0.95 lambda whereas another can be 750-800 degrees at 0.8 lambda. It all depends on engine efficiency etc.
The rule we use for E85 injector sizing is 1200cc of fuel for every 100hp at the wheels
The thing you are missing with Methanol is the rate of evaporation and even considering its calorific content per unit of mass, methanol has a higher content of oxygen so when it burns you get a leaner mixture
Now before anyone jumps on me about injector sizing and 'oh but I made xyz hp on abc injector' etc....it is designed to be a safe level for injector sizing. With those calculations, you will NEVER have an injector size problem unless you increase the hp.
Most of these engines need 10.5:1 AFR as they come up to peak torque but seldom do we ever see that when cars come from other tuners......and that's why the engines that Sean tunes for us live a very long and healthy life.
A man's worth should be judged by his achievements not the money in his pocket. ;)
besdies Im a broke ass mutha regardless...
And by his skidz! I'll be broke for the next 2 years due to the mods i just went through...... Worth it you ask?.........................................................Fark yes!! :woot:
I think most cars from other turners don't have AFR's that rich because they don't believe it's needed. I know we sure don't have a need to tune that rich and don't have issues (very long and healthy life motors), but if it works for you then all power to you.
Fugged if I know.
I dropped in there yesterday and asked what's going on as they are listed as having E85 on the website. There were two guys behind the counter, one stared blankly at me, the other clearly knew what I was talking about. The knowing one said they dug up the forecourt (which you could see) to install the required lines but then figured out that the tanks were fibreglass and therefore unsuitable for E85.
Would be interesting to hear from someone in the know. I assume the alcohol and fibreglass resin probably do not get along too well? Anyone know the chemical reason (assuming that is the reason) why there is a problem with putting ethanol into FG tanks?
In your case, with a single 044 running the show, your tuner probably has no choice.
I'm also referring to cars that actually do fast 1/4 mile times. They are the ones that matter
What are your EGT's?
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
