Iain did say that it made a difference.
Not as significant as the front brace; but it doesn't deal with the same kind of loading either, but he felt it was worthwhile.
I'm getting one. ;)
  • Replies 182
just ask someone who has one right now...i think iamhe77 has one on his, or zel02 who owned the bars previously
I can't really compare it with and without as it came with the rear bar (and a "different" front bar) installed already and I have not been bothered to remove it yet.
I can tell you that it corners much better and flatter than my NM35 which had Nismo suspension (current PM35 has Bilstein struts and stock springs).
OK for those that have said they want to be in this I will be sending you a PM by EOB today. If your in and you do not receive a PM from me please contact me.
Just a heads up guy's....I will not be chasing you on this....if payment is not made by the 1st you wont be on the GB.
Can you please PM me back when payment is made.
Edited by Jetwreck
Done, thanks Craig.
Would I be correct in saying that delivery date is likely to be minimum 8 weeks from 31 July?
You said 6 weeks for production in the opening post, so I figure a week or so to deliver to Australia, then about a week for them to reach the individual states?
Done, thanks Craig.
Sounds about right........give us a couple of days to process payments to OX though.
Will OX be wondering why they are selling heaps of rear braces but no front ones? :whistling:
Hey guys i wont have enough this week to put through but i dont get paid until tue 31st, is that okay or am i out. Because ive got sway pars and links and all i need now is this and daleos front and its done?
I'll pm you when I get to my laptop...should be ok.
this worth while for v35 coupes? scotty on another note im gonna get a GT3582r 1.06 rear .70ar front housing - using HKS ST 3037 kit, do i need anything special to make it fit?
is this bar a must or do i just get the front ? i got every other handling mod lol
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
