Entries Open: Import Monster Sauvic Deca Motorkhana - September 8 2012
lol roman, I'll be faxing it off tonight at work. Do I need to also fax the print out of the money transfer.....?
just need to fax the entry form, but faxing the money transfer receipt too can make it easier to match your entry form to the payment
  • Replies 343
sweet, payments done. :D NOW I CAN GET EXCITED
Good, good
Entrants Disclaimer/Declaration
I Jacquii of _____?______
lol silly ques but what do i put
I always put the address...
and AASA no. .. i just wrote.. getting on the day?
Thats fine
You can laugh at me now if you like.. Get it over with lol
HAHAHAHAHAHAHAHAHA
Yep address. Eg Mark of 123 fake street
Mark of 33 I Eat Dick road....
i have got another mate keen, and his 2 brothers, if they come n sign up, will be driving a modded s13, highly modded bf xr6t, and i belive possibly a turbo ef falcon, hopefully they come,
Also, is there any charge for anyone who decideds to come up for the day/ avo to watch?
And is there any accomodation that people are organiseing? My mrs and i might be keen on staying there the night after the big day!
one of my mates is confused, and im not sure on the answer either, do you have to be a paid member to enter deca? or can any signed up un paid sau member enter?
It's posted in the non members area (open for all to view), assume it's not members only I'd reckon.
Don't have to be a paid member.
Toyrona is booked for a thrashing.
I'm just waiting for a reply from Ryan and then I'll do my entry.
I don't want to rip this club off only paying $50 instead of $85 if that's not what I am meant to pay.
Ryan has been a great help so far so hopefully this won't be the last event I come to
Cost is $50 if you ARE an SAU VIC Member and have NOT done a DECA before.
Cost is $85 if you ARE NOT an SAU VIC Members or you're a SAU VIC Member who has done a DECA before.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
