Entries Open: Import Monster Sauvic Deca Motorkhana - September 8 2012
lol roman, I'll be faxing it off tonight at work. Do I need to also fax the print out of the money transfer.....?
just need to fax the entry form, but faxing the money transfer receipt too can make it easier to match your entry form to the payment
  • Replies 343
sweet, payments done. :D NOW I CAN GET EXCITED
Good, good
Entrants Disclaimer/Declaration
I Jacquii of _____?______
lol silly ques but what do i put
I always put the address...
and AASA no. .. i just wrote.. getting on the day?
Thats fine
You can laugh at me now if you like.. Get it over with lol
HAHAHAHAHAHAHAHAHA
Yep address. Eg Mark of 123 fake street
Mark of 33 I Eat Dick road....
i have got another mate keen, and his 2 brothers, if they come n sign up, will be driving a modded s13, highly modded bf xr6t, and i belive possibly a turbo ef falcon, hopefully they come,
Also, is there any charge for anyone who decideds to come up for the day/ avo to watch?
And is there any accomodation that people are organiseing? My mrs and i might be keen on staying there the night after the big day!
one of my mates is confused, and im not sure on the answer either, do you have to be a paid member to enter deca? or can any signed up un paid sau member enter?
It's posted in the non members area (open for all to view), assume it's not members only I'd reckon.
Don't have to be a paid member.
Toyrona is booked for a thrashing.
I'm just waiting for a reply from Ryan and then I'll do my entry.
I don't want to rip this club off only paying $50 instead of $85 if that's not what I am meant to pay.
Ryan has been a great help so far so hopefully this won't be the last event I come to
Cost is $50 if you ARE an SAU VIC Member and have NOT done a DECA before.
Cost is $85 if you ARE NOT an SAU VIC Members or you're a SAU VIC Member who has done a DECA before.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
