Bringing back an old topic, I don't think highway patrol care about 'poke' as long as the wheel is sitting pretty much in the guard
Two officers checked my car yesterday after they pulled me over for a random check and said nothing about my stretch or poke.
However it may depend on the police officers too.
735041 413290632084687 2387347 N
while its nice to have deep dish, flushed wheels... wheels that stick out, IMO look weird.
btw anyone knows what a good offset for 19x9.5jj wheels to be on the BNR34?
also, if the overall diameter of the wheel + tire is close to stock...is it legal?
[quoted from VicRoads here]
"The overall diameter of any replacement rim and tyre must not be:
-more than 15mm greater than the largest diameter tyre specified by the vehicle manufacturer for that model or vehicle series, or
-more than 15mm less than the smallest diameter tyre specified by the vehicle manufacturer for that model or vehicle series"
thanks for clearing that up =)
+12
i think it was said a few pages back, but that might be the 'increased track' rule,
But Rims and tyres must also not "foul any part of the body, suspension, steering or brake components; at any position of suspension travel, steering movement and when in the straight ahead position"
[Keep in mind, this is coming from the Victorian Vehicle Standards Information]
Edited by alex182
i'd imagine as long as the tops of the guards don't foul the tyres it'd be ok. as long as you're not running ridiculous amounts of camber.
Lots of cars have bumpers that narrow inwards
Stanced cars have always looked broken to me. Especially from the rear, and I dont see the point of fitting massively wide wheels only to camber them in just to fit the tyre into the top of the guard
With that amount of camber and lack of rubber on the road, stiff suspension and crappy tyres (in most cases) braking performance goes down the toilet
Edited by junkie
  • Like 1
Yeah, plenty of these cars you see around are just funny to watch. thanks to the stupidly stiff suspension they bounce around worse than a vn commodore that's sitting on the bump stops.
People seem to think that stiff coilovers are going to make the car handle like it's on rails. This might be the case if you drive around on a big sheet of glass, but in most roads a car with stock suspension will out perform a car that bounces around all over the place
^^yep, couldnt agree more, when i got my 32gtst the f*kn thing was stupidly low on stiff springs, whilst it looked the goods it skipped/bounced over every bump on the road, i returned it too standard and it was a LOT more pleasant to drive
I beg to differ, my coilied 34 handled so so so so so much better than my stock 34
what spring rates did you have? i bet they weren't 11 or 12kg springs like what some people put in. ones like the tiens only have about 8kg springs and will actually ride well. i had some unknown rate coil overs put in the front of my 180sx when i still had it. they were in there for 3 days before i pulled them out and put the old shocks with the old lowered springs back in. i went around a corner near home at 40kmh and started to bounce onto the wrong side of the road. i could normally take it at about 60kmh and be on the verge of losing traction.
thanks for the pic alex182 :)
the "poke" look, looks so wrong and possibly dangerous.
mad082: I think its not just stiff springs that causes it. I believe the phenomenon is bump steer...and it could also be due to the insufficient suspension travel that would cause the car to bounce. I had the Tein superdrift in my 180sx with hardness setting to slight more than half. I have also tried with the max hardness setting... high speed sprints (~220km/h) and corners (~90km/h) were fantastic. car was really planted to the ground and traction was amazing...but of course proper camber and toe in are required as well...
Tein Superdrift spring rates are 10kg front and 12kg rear if i rem correctly.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
