Hi all , I'm weighing up the E85 (Eflex anyway) on the existing RB25DET vs going the RB30 route in my R33 .
I've being reading through Guilt Toys E85 thread and he does make it sound reasonably easy . 740 Nizmos I'm running with a 33 GTR pump and the dryer is a GTRS . Intercooler is a GTt SMIC that needs upgrading but as always I don't want the constabulary breathing down my neck .
Have to run ATM but its obvious the jungle juice 25 is much easier and no doubt lots easier to fly under the EPA radar with .
I think Eflex is available at Heathcote and Tempe servos so not too far away
Back later , cheers A .
  • Replies 87
If minimising trouble with the cops is a priority (and it pretty much has to be for any car that isn't track only) then E-85 is a very very smart choice. You can probably even get away without upgrading the SMIC (to a certain extent) due to the cooling friendliness of the fuel.
E85 improves off boost torque significantaly i found with my car and the Engine just runs WAY nicer and is more powerful everywhere and sometimes you get nice surprises like this when you go to the bowser20120708_111850.jpg
Yep that was my thoughts and reversing it just means using 98 mapping . Thinking about it even changing to an ECU that can do flex fueling properly is cheaper/easier .
Can the Vipec or Link plug in do this or only V88s ?
Cheers A .
Cheers A .
I know the Link G4 plug can do it as I'm using that ECU on my own car. I would assume the Vipec could do it also!
That whole 'flex fuel' setup rocks.
Here's another option that I'm currently putting together..
I have an Adaptronic which is also flex fuel capable..But buying a sensor and all the extra tuning needed can get expensive and I can't yet afford..
I do however have a pulp and e85 tune already and an ecu that can run dual maps..so I will put a switch in dash that can just switch between the 2 maps..This will only change my fuel/ignition however and can't adjust the different boost pressure which is also controlled by the ecu..so I will set the pulp tune to gate pressure and let the ecu run boost on the e85 tune only..so when I switch to pulp map it will also switch the boost solenoid off..
Admittedly its not as ideal as a full flex setup but I think it's a good compromise that saves me carrying my laptop around and should be good enough to get me out trouble should I drive to an area that doesn't have e85 available.
Adaptronic (if you're willing to give it a go, I will be sometime this year) has provision for a e-flex setup. However it only runs 2x maps and interpolates between the maps based on ethanol level. Also has input for wideband and closed loop operation
Aussie built, and cheap as sht. Not to mention has built in launch control (not like I would use it on the street LOL). I've played around with it before, the GUI isn't as "sexy" per say but it does the job and simple enough to use.
Oh IMO, stick with the RB25, spend less cash load it up with e85 dial in the timing. Save money for other sht.
Yes but you explained it better.. :)
So if it interpollates as you say, does that mean I only really need the 2 maps and the ecu figures the rest out in between ?...if so maybe I should just get the sensor and wire my wideband in already, I got it mostly for a gauge for now
Haven't yet tried the launch or traction control..also has a boost by gear function I might have a play with to try prevent those 3rd gear tank slappers..
that is correct, it uses 2x maps and depending on the ethanol content it goes "hrrmmmm ignition & injection looks about right HERE.." Ideally there should be a table which allows ethanol percentage vs. ignition trim, but I do not believe there is last time I played with it.
Why haven't you wired in your O2 wideband? ZOMG... close loop for the win man, up that economy!
Haha, Just haven't got around to it..atm my track economy is almost as good as my road economy.
But thanks you have opened my eyes to the way my ecu works..its even easier than expected. Allthough this doesn't solve the problem of adjusting my boost either..which means the flex fuel option is only good for a set boost level or I can only turn the boost up when the sensor says e85.. :D
damm where are u filling up.. $1.29 last nite here in brisbane :(
what is the actual cost of doing an rb30/25? without going into massive detail, just interested in the actual cost comparison for the future assuming you do most of the labour side yourself and get machine shops to do the other obvious parts..
i think it might be a downside having a reduced redline..
Plenty of people run the stock RB30 bottom end to 7000rpm... I mean really your making the power like 1000rpm sooner so you end up still having a larger power spread, which is basically the whole point of doing rb30 lol
Anyway my vote is for both :) but if your sticking with the GTRS then its probably not worth the extra hassle for the 3L..
Edited by battery
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
