hybrid performance manifold, using one with gt3582r and another with precision 6266... cannot beat the price and value.. you would be stupid 2 purchase anything else around that price range. specially the cheap chinese shit. we all know the problems they have.
  • Like 1
Yeah not too bad with the ring spanner, I recall there was one that I could get about 2mm of movement so I got the grinder out and cut the spanner :D I'm just lazy and love using ratchets. But brilliant value for money.
My cars still in the build stage so cant report too much on their durability but the welds were good, the position of the turbo flange is great, lots of space to the cam cover. alot of the stainless cheapies wont fit most aftermarket turbochargers.
I had to make a custom mount for the power steering reservoir as it fouled on the compressor housing.
Edited by Crazy Xav
How long have you been using the Hybrid manifold?
what turbo are you using with it?
They don't look to bad for $350-400 and there made out of steampipe/mild steel
I'm using a hybrid one with a 5558 Been on the car for about 3 months
So far Done about 3000kms maybe
Including drags at wsid and a trackday at Wakefield .
I can not complain for price
I had to make a custom mount for the power steering reservoir as well... It took all of 20 mins, if that?
I've had the hybrid mani on the car for about 1000kms now (car sits at 370rwhp), it's been a hard 1000kms :-P
Was probably the most straight forward Part of this Build lol.
Did you make a brace for you turbo? Im thinking of making one utilizing the bolts that hold the crossover piping to the head.
We will have some low mount ones that we are working on, which will be available in a couple weeks , The ones we will be doing will be good to run with a 38mm wastegate , if you are wanting to run big horse power i would suggest going for the top mount with a larger wastegate port, Low mounts are a mission and cramps everything in a tight spot so its quiet hard to make something which will look half decent and will also clear everything.
  • Like 1
I haven't made one yet. I had the same idea. Only because there is a lot of weight hanging off those exhaust studs in the engine block. The gyrating force of the turbo (not sure if that's the correct term) would put a but of strain on those studs as well.
yeah hot manifold + the weight of the bits attached would put alot of strain on the studs, hate removing broken studs! I didn't think the turbo spinning would affect too much if its properly balanced but then again, I am no turbo expert, thats why I'm on these forums :yes:
Ill get some steel and see what I can do for a mount, should be quite easy as the Hybrid manifold has both T3 and T4 bolt holes so i can mount to that.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
