Good afternoon Benjamin,
I have reason to believe you may have taken ownership of an R33 GT-R recently and, perhaps more importantly, this car may be of a higher specification than many others.
Would you be so kind as to share some images and details of the car in question such that we may all enjoy its beauty and outstanding quality?
Cordially yours,
Dan.
Edited by ActionDan
  • Haha 7
  • 3 months later...
This week we are working on the nightmare of mounting the EFR. There is NO room in an S15 engine bay.
To anyone reading thinking of using any bigger than dual 38mm gates on an SR, don't!!! You will end up panelbeating your car to make it work. Thankfully, we have millimetres to spare and don't have to do that.
The wastegates are in the way of the turbo drain adapter, so this will be sorted with an Aeroflow 8 orb to 10an swivel adapter arriving this week. Speedflow wastegate fittings are ordered so we can plan our route to the MAC valve, and after that finish the remainder of fabrication in the engine bay. The next hurdle will be the NASA fuel system which will take a LOT of hours to sort out  : | .
Looking forward to refitting the interior, front bumper and taking it to the tuner.....
It's amazing how as a build progresses there are unexpected changes, especially upon the realisation that modern day tech from other countries is light years ahead of a 'japanese nostalgia build'. The car wouldn't be where it's at if it wasn't for the intervention of Piggaz & Mick_o, the most expensive BBQ I've ever had as the build went in the complete opposite direction.
  • Like 1
  • 5 months later...
Progress on the S15 continues, just received these photos.
Remainder of work requires mounting the catch can and then it'll be 100% ready for fuel system, wiring & ECU.
The oil drain was next to impossible to fit and had to be machined on an angle with special fittings. The 6boost manifold sits it in a spot with NO ROOM. If I had my time again, I'd pay the extra and run a Hypertune manifold seriously.
Dual map sensor provisions welded on. Intake pipe fab complete & the air filter/catch can will be fully enclosed. A lot of work went into the power steering reservoir & -10AN catch can. The underside was rolled in two planes to the shape of the strut tower, & it also features a pretty complex internal baffle arrangement, a provision has been made to run push lock hose for when I need to drain the can.
4 port mac valve is all hooked up with teflon line goodness.
So in the meantime I'll refit the interior, front bumper & bonnet, & fit superclamps to the intercooler piping.
The next few months will be slog to restore my bank balance so I can spend on a TRP fuel system & Insight ECU package. After that, the likelihood of me spending money on cars, unless something is broken, is close to zero.
On 7/16/2019 at 8:35 AM, ActionDan said:
Also, I am not looking forward to trying to get my engine and all the shit into my bay either, this is stressing me out looking at the clearances lol
Since the EFR plan came to fruition, over 140 man hours & counting.......
1 hour ago, BakemonoRicer said:
Dan if you haven’t bought your manifold already I think a hypertune manifold will give you more room for plumbing...
No I haven't yet, thanks for the heads up. Was yours 6boost?
Yes 6boost. Not to mention the EGT on the first runner was installed at the wrong angle hitting the cylinder head, and that took them 3 months to fix rather than sending me a new manifold. The 6boost manifold I had for the 3071R...I just got a message from the bloke I sold it too that the wastegate flange cracked off completely. So I think a Hypertune item is a better path.
Appreciate the insite.
I have heard mixed things about 6boost these days.
  • 4 weeks later...
I present to you the EFR7670 Street Drag S15 SPL (formerly the Rising Sun S15 ?).
Very thankful to the mechanic/engine builder who got the car to this stage....the amount of thinking that went into this build was huge, and his work really is flawless with meticulous attention to detail. I can't imagine how much I would of been charged if the car was at any big name Sydney workshop.
Remainder is interior/bodywork refit, the fuel system, battery relocation cabling, oil catch can push lock drain hose, wiring & ECU.
I'll need to somehow sort a custom cap for the radiator breather tank as the one from Sunline Racing doesn't seal properly.
The size of that turbo has WARP SPEED written all over it ? #TEAMEFR
  • Like 1
20 hours ago, ActionDan said:
What power are you expecting from this setup as I've been looking at turbos...
Whatever a reasonable limit is for a stock SR20 bottom end. Don’t forget the gearbox is made from glass so that’s a grenade waiting to explode.
All in it should do somewhere between 400 and 420 kw on E85, on a roller dyno.
Fark, these things are pretty light to
Should be good for some mad skids
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
