1 hour ago, ActionDan said:
Stock bottom?! Wasn't it done with the $$$$$ head?
Assumed stock box would be removed as nobody would expect it to last behind anything decent, especially a 6spd.
"Apparently" the same type of Aisin AZ6 gear box that's in my 86
Rated to 250nm
I learn something new every day!!!
Stock bottom will go bang with 400kW+
Box will die easily with 250kW with a few laps at Wakefield.
S15 bottom will do 320 to 340kW with torque being limited either via timing or boost control strategies.
Should do a 5 speed swap using a R33/34 RB25 turbo box.
None of my cars will be seeing the track, I'd rather just enjoy the cars every now & then.
That's enough for me, I'm not a millionaire to be able to afford track days or risk losing everything.
I'll have to assess the gearbox stage carefully.  My money can go so much further on travel around South America, so Id rather ignore a gearbox solution as long as possible.
What do you mean no track? ;)
On 6/1/2019 at 11:43 AM, BakemonoRicer said:
Haha I’ll float the car to Adelaide and line you up on the circuit mate. We can put $5000 on it to make it worthwhile. You’ll probably get crossed up trying to match my late braking & end up in a tyre barrier, so when I win you shall refer to me as “The Don” and comment my thread admitting the car is a museum piece
  • Like 2
  • Haha 3
  • 4 months later...
Overr the christmas holidays I decided to get stuck in and work on the car. Started off with reinstalling the bonnet & mocking up the front bar. Installed a big spec Cusco Swaybar setup. I was really pedantic on making sure its completely equal each side, so measured off the chassis rails until it was exact (a step most people miss for the front which can be done wrong very easily). Swaybar was installed with the wheels loaded on the ground, and all new OEM endlinks & endlink bushes.
Next step was to sort out the interior, so I worked on running all the sensors for the DEFI gauge & the positive battery cable to the boot. Aligned everything real nice & it was back to looking like it'd never been taken out.
The engine bay is really starting to come together, the next step is to get the car towed to TRP for another don mega fuel system, then get it wired & Emtron'ed...I'd like to think I'm only a few months away from having the badger up & running.....
  • Like 1
Good work.
What shocks are in it? I found that my car had a lot more grip opn stock sway bars, with a whiteline in the front and GT-R in the rear it was full flat cap drift spec and just wanted to slide everywhere and would not transition weight smoothly.
Could be because it has those cheapo BC golds in it, firm spring etc.
  • 1 month later...
Bought another Emtron KV8 last weekend LOL. So now it's simply Fuel System, Wiring & Tune to go.
Dan, the coilovers are HKS Hipermax III 6kg F/4kg R. The Ohlins in the GTR kill them in every department, but that's comparing apples with oranges really.
MLR, no the swaybars aren't adjustable.
I had those in my first GT-R, the Hypermax, I quite liked them.
Keep some stock sway bars on hand for tuning the setup, you might find it's too stiff to put power down cleanly.
Good to see some progress again. Nice work.
Why dude? You have a gearbox that is lucky to survive with the stock turbo bolted onto it. f**k the 6 speed in your car makes a WRX gearbox  look strong!
You have a stock motor that will be able to be turned up to what 270kw max? Throw a single 525 in the tank and put your money to better use dude. You won't even need E85 for that kinda power with the 7670.
My car was at the power/torque limit of the motor at E15 dude so theres no way you are gunna be near those numbers lol. Dexter said you are out of motor that's it.
You do know Scott WILL NOT push the limit of a stock motor. Take it from me i know! He will give you whatever he feels is safe and that's it.
I really struggle to see your logic in these $4-5k Don Mega fuel setups for a million kw when you literally need a $250 single in tank pump to start enjoying this car?
Put your money towards a gearbox, a diff and at least some Evo calipers to help this thing put the power down and stop...
I can assure you it won't make it off the dyno with that 6 speed mate & you know it. The fuel system money is literally your gearbox & diff almost paid for.. Then theres the other bills you dont see like the tow truck back to Rigoli & the dyno time you will pay for with an incomplete tune.
THEN pay for another tow back and the tune to be finished. Give the tuner a car setup properly so it goes on the dyno and gets driven home not 1 that that leaves on a tow truck for repairs cos it's broken!
It's a beautiful car with all the cream dude why hold it back with shitty stock parts for junk that you simply DO NOT NEED ?‍♂️
Edited by Mick_o
  • Like 5
^ Completely agree.
My fuel system won't be anywhere near the Don Mega Spec stuff and my SR will make a fair chunk more power and be used in harsher conditions - and happily.
No way would I attempt 300kW on a 6spd box either. A 5spd might barely hang on with really gentle shifts and soft torque ramping but realistically you need to budget for a Z32/RB25 or better yet CD009 (if you want manual).
Edited by ActionDan
Much agree with Mick_o but i like the Don mega spirit as long as im not paying.
So to complement the Don mega fuel system, how about a Don mega gearbox (samsonas, hollinger, ppg, albins, tti, etc. choose your flavour). Run your 300rwkw+ without gearbox explosion at any time hanging over your head. That would be Don mega, not to mention f**ken quick.
Finish off with number plate
THE DON
DON MEG
DONMEGA
DONE
It needs the fuel system that’s what makes the power it has to be delivered efficiently to quench the thirst of the big port head! Already stripped the stock pea shooter hard lines out its time for the Teflon don upspec. Fuel pumps, flex sensor and custom alloy surge and hat all done.
Gearbox is the only weak link, if I blow the 6 speed That’ll get turfed for an AL’s RACEGLIDE!!!!!!!!
  • Confused 1
lol, no Benny. It does not need that fuel system to suppotrt 300rwkw - regardless of what's in the head.
We've been down this road before though, you get an idea in your head and it's very hard to convince you so just go ahead and waste the money, no skin of our noses :)
1× 525 Walbro supports my tiny 325awkw on E85 dude. So it will support your 260rwkw on 98 just fine.
If I was you I would call Al and give him a deposit on that glide now so that way it's ready to be swapped out on the dyno. Hopefully the box lives long enough for at least 1 power run for that dyno sheet ?
  • Like 1
You guys just don't get it.
Those pumps only work for you because you don't have a Don mega flow head from Naprec.
Sure, the combo is going to be dialed down to help the bottom end live, but big heads need big fuel. Even if 80% of it is being returned to the tank.
The higher flowing fuel in the rail just makes everything smoother and better.
Duh.
  • Like 1
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
    • OK, now we are ready to get started. You need to remove the air boxes on each side for clearance. The cover is straightforward, undo the clips on the top and lift the front cover out of the rest of the housing. If it is tight you can remove the air filters first. The rear section of the airbox is trickier. On each side you need to remove the Air flow meter wiring which is held to the airbox with a clip; you need to get behind the clip on 2 sides if you want to remove it without breaking it - unclip the harder side and pull on the clip with medium force, then unclip the easier side and it should pop out The airbox is held onto the intake hose with a spring clamp; you need to get a flat bladed screwdriver behind the spring on both sides and pop them outwards. When you have got them in the right unclipped place they will stay there and the airbox slips out pretty freely. Put a rag in the intake to prevent anything getting dropped in there, and also to prevent you seeing that the turbo seal is leaking oil (as they do). Then. The top of the radiator is held by a steel plate, it is secured by 2x10mm and 2x12mm headed bolts . Remove them and remove the plate Also grab the bushings that hold the radiator to the plate on each side so they are not lost!
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
