Read: "I don't know"
Meh, I'm just here for the biscuits.
I believe the stock gearbox is good till 250nm, I think it is the same Aisin AZ6 thats in the BRZ.
So.....needs more T56
59 minutes ago, ActionDan said:
Fair go.
You know how rarely a car goes on and off the dyno as scheduled lol
Normal cars yes they have issues, this is not normal. NASA spec aeronautical aluminium etc
  • Haha 2
My thoughts have changed.
Car made so much power and was so impressive the shop wouldn't let it off the dyno. They can't believe it is possible and are getting dyno checked over for faults.it it is made harder because everyone is deaf because of the extra noise caused by special 2into 1 exhaust merge and no squish pads in the head
that or they are still trying to figure out to strap it down
  • Haha 1
Yes it definitely is a special merge for the ultimate sound and I will sue if anyone tries to copy me
It's a mission to hold the thing back, it is making power in a way that JUST hasn't been seen before.
I paid a premium to NAPREC for their special ingredients, it's their only Australian SR20 so they just went full-tilt. It's a stage 5 head.
  • Haha 1
Did you get a stage 5 result yet or what Benny???
6 hours ago, Mick_o said:
I have a feeling it may only be a stage 1.5 result ?
Stage 4th gear results maybe?
With the head that decimates all, it may have made don torque low in the rpm range and made 4th gear go bye bye.
Bokey, tell them the price son....
On 26/06/2020 at 2:18 PM, mlr said:
45 minutes ago, Ben C34 said:
He is actually working for NASA now. They couldnt  believe how well the merge worked and are going to use it on all their rockets.
It's all about where the merge separates
  • Like 1
  • Haha 5
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
