I've got a 3" exhaust off the factory dump pipe and would like to replace the stock dump pipe with one that seperates the w/g gases.
Should I go for something like this that looks like it would bolt in and replace just the stock dump pipe
http://www.drivenperformance.co.nz/scripts/prodView.asp?idproduct=329
or go with a whole front pipe which seperates the wastegate for much longer (this just means I need to get my existing exhaust modified to suit)
https://www.sau.com.au/forums/topic/410435-dump-pipe-or-front-pipe/
All a split does is create more problems, cheap ones almost always have the internal wastegate flap getting jammed against the splittter you can see in the photo that seperates the 2 streams of gases
Except for when you install them carefully and properly (like mine) and then you get no such problems.
and so when it is done properly like this what does it truly do?
create a more stable flow/boost pressure?
iv got this setup too that works perfectly but iv always wondered what it truly does over a big bellmouth...
If you were looking at a split dump I'd say look into the CES split dumps. Apparently these utilise a a longer split pipe, unlike the JJ ones etc and are supposed to effectively reduce back pressure on the waste gate flap (iirc).
So therefore I'd say the full split front, and not the just replace the stock dump.
Edited by gtsttrk
The point is to stop the wastegate exit gas flow from splashing horribly across the turbine exit gas flow. If you can keep them separate, the idea is that the turbine exit gas gets a much more efficient expansion out into the dump, resulting in lower overall backpressure, or more to the point, more pressure drop across the turbine (meaning better power available to drive the turbine). The wastegate gases are then dropped in much further down where they don't interfere so badly.
The CES dump is possibly a bit nicer in the conical expansion of the turbine exit region than the cheapy is, but as far as I can tell, the return point for the wastegate flow is about the same distance down the dump. This is for the case of the split cheapy shown above. Any of the really short split cheapies, where they are intended to only replace the factory cast dump and mate to the original front pipe, are the ones that are not worth considering.
When I changed to my cheap split (JJR I think - many years ago now) I gained a good improvement in boost threshold, more stable boost control, and an increase in max boost that I then had to adjust out. That shows me that the wastegate flow was better (boost control improvement from less intereference between wastegate and turbine flows), that the overall pressure drop was lower (better boost threshold) and that the flow at high flow rates was better (increase in boost). Overall, it has been good.
The only open question is whether those changes would have been the same, less, or greater if I'd gone with a bellmouth dump. I don't have a comparison.
Most of these guys around here just write off the concept of the split dump though. I can't understand how they refuse to accept the idea of them, yet all agree that an external gate on a bigger turbo is a better idea. The ideas are related.
Does anyone have an example of a split that brings the WG flow back in basically where the the dump joins up with the cat? I've had a look around but haven't been able to find any that are produced like this.
never heard of such a design. N also could imagine why it would not exist as trying to merge the gas flow as it is also dealing with another change (going into a cat) could reduce efficiency of the design as opposed to merging it a bit further up the dump pipe- just like in the pic by the OP
Yeah I worded what I was asking very poorly, too much excitement from the granny lol :laugh:
Basically I was asking if anyone knew of a split like the one in the OP posted a pic of. Virtually all the ones I've seen either just replace the stock dump, or utilise the shorter split such as the JJ, CES etc.
If you're not making loads of power and using the stock turbo especially, you're not really going to notice any real gains with the split, not to mention there's room for it to jam and give you headaches down the track.
Save the coin for a slab of beer and just get the bell mouth.
Ok, so it looks like the latter is the better one of the 2. Had a hunt around for belmouths and there aren't any readily available. either way, its gotta be better than the stock dump. i'm interested in the gain i get vs my stock dump into 3"
I've used a JJ split before and didn't think that it was a bad little piece. Had it installed correctly and I definitely felt an increase at the RPM's that boost came on. The spool definitely seemed to come on earlier than when I was using a belmouth. Mind you, this could have just been a placebo. But the JJ split isn't bad for what you pay.
Just out of interest, has anyone used any of the CES products that I mentioned earlier? If you look at their website some of their products boat huge KW gains for what they are.
This^^
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
