So lets clear up some of the rumors......
The original Nitto 2.7L blew a head gasket at power cruise in 2010 when we were running the GT47R through a mixture of too much boost and also too much coolant temp (it copped a cainning!). We didn't time to repair it before Autosalon, so we decided to run the car on the dyno as it was. On 40+psi it made 1072hp, but had sucked in some coolant and damaged a rod. This caused a rod failure AFTER autosalon at a photoshoot under light load destroying the N1 block. The engine was removed and replaced with a standard 05U rb26 and a T04z setup as we wanted a street style setup and we had spent a lot of funds to get to that point. The stroker kit was inspected and any damaged items were replaced and since then we have sold/fitted the 2.7L into a customers car.
For the past 2 years we have been running the standard engine and with great success, using E85 and generally running around 30psi boost. I now personally tune the car (I didn't with the 2.7L engine, it was one of my staff) and switched to a HALTECH ECU. The T04Z was getting boring, so we had a play around with a few turbos (doing more R&D) and eventually we installed the Precision 7675. I wanted to see how far we could go with the standard components as 2J's are always referred to as unbreakable and I thought it was time an RB got some credit! It went into the 700's (hp) and I was having a chat with Mark @ Godzilla. I asked if he thought 800hp was possible and he kinda laughed at me. I dont mind a challenge, so I had a new goal of 800hp. We got to 805hp and this particular engine was hanging in there pretty well! We had run 30psi, then 35psi, then 40psi! it just wouldnt break! Hell we even threw a 100 shot of gas on there for a bit more response. To me it is experimenting, but on my own gear. It allowed us to play with the Haltech ECU and use many more of its features other than just timing and fuel. It runs everything including the NOS, flat shift (when we put the sequential in there), coolant pressure protection, complete engine protection (temps, pressures etc) full EGT on each cylinder and also post turbo....the list goes on.
We are the first to realise the standard engine is a timebomb (yes we are realistic!) and wanting to do something different instead of just another 2.7L (as we had already done that), we have been building a 3.2L Nitto engine over a period of time whilst using the standard engine. This engine is getting the works including sleeves, billet main caps, 4wd girdle plate and a few other little goodies. This will be combined with a new custom head (bigger and better!) and a larger precision turbo. Our goal is to build an amazing street car with 1000hp at the wheels that can be used at Powercruise events, off street drags, air strip run, 1000m races etc.
We love our 34 GTR so stay tuned for more updates as we fit the new engine and attend more events, showcasing it performance.
Trent
Trent
Damn. I liked the rumor that the rod bent BEFORE the autosalon dyno run. lol
It's sounds like you have had alot of 'fun' with this car over the past two years and i'm actually keen to see you install the 3.2 and poke it with a stick.
I look foward to seeing furture updates with this car.
Hahaha! We liked ALL of the rumours... :P
We also like the one where apparently we're using an N1 block as our 'stocker' that's currently making 845awhp!
It's all about R&D, it's been a lot of fun pushing boundaires & we're blown away with the power that we've got out of that stock 26 so far... It's a credit to Trent's tuning.
Looking very forward to popping the 3.2 in, that's for sure :)
Up until 1 month ago, it had standard sump with the oil just filled to the top line on the dipstick, as you would with any car. When we changed the diff ratios, we installed a 9L sump and again filled it to the top line of the dipstick. WE HAVE NEVER OVER FILLED THE ENGINE WITH OIL!
You could have at least wacked a set of billet pump gears in when you had the sump off you stingy bugger :)
Edited by SimonR32
anything under 6l with 800hp and the bearings would be toast a long time ago.
How? What diffrence does 800hp make? Any engine weather it be a Suzuki mighty boy or a ride on lawn mower, if it don't the right amount of oil in it, the bearings will b toast.
It doesn't matter how much power you got.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
