Also looking at getting a PAR dog engagement gearset, 1st-4th, pretty cheap. Any reccomendations?
All I'll say is - do your research. Enough info just on this forum alone to make a decision about that type of thing...
PPG Dogboxes seems to be the strongest on the market at the moment, I have great results with mine. Just remember to upgrade the stock sandwich plate with a billet item cause if that fails then everything will as well. Have done over 50+ runs, all over 800-1000awhp going through it, you wear clutches out before the gearbox I highly recommend them.
there goes that idea then! must remember, you get what you pay for -.-
man up and get an OS88 sequential! :P
but def keep us posted as to what you do because ill be heading down the same path shortly so will be interested to see which way you go
Edited by Frosty
Hi everyone,
About time we posted this up - here are the specs on our "NITTO" R34 GT-R:
STANDARD RB26DETT bottom end
ARP headstuds
Nitto Headgasket
Standard oil pump
Custom head by Mercury Motorsport
6Boost mani
Precision 7675BB turbo
Twin Precision wastegates
4" exhaust custom made
Haltech Platinum Pro ECU etc.
Upgraded fuel system
Splitfire coils
100mm thick FMIC
Custom i/c piping
OS Giken sequential gearbox
Power: 622awkw/845awhp @ 43psi (ran in 5th gear, to keep the 1:1 ratio due to gear changes, 6 straps holding it down)
Nicely done. It's no easy feat to make 850hp but glad to see you finally decided to run it and put the shit talkers to rest.
I can gladly agree that you indeed make over 800hp and am very interested to see you push that stocker as far as it will let you. At this point, even if it broke, you're currently making more hp than any other stock RB26 that I know of. Well done
Not sure if you are talking about Oz, or in the world... but Manny Cruz in the States claimed ~950whp for the stock bottom end RB26 he had in his Sentra drag car back in 2005, lots of people called BS - though the car ran mid 7s at >170mph and there is no reason for him to have lied about the internals - DSport in the US also had an R33 GTR they were claiming ~800whp for a few years ago with twin RX6s on the stock motor IIRC.
Not when it weighs 1700kg
It would either need that power with 1400kg to run 150 or it would need to make 1000hp at the weight it is.
Cheers Dan...
The Powertune GTR weighs 1800kgs including driver (we thought 1700kgs too, but speaking with Chea, it was 1800). Anthony & Trent are about the same weight & both cars are in full street trim with big brakes. We'll weigh NITTO in due course! :)
Mates vl calais 1400kg plus driver, with 385rwkw ran 139mph.
Same guy now has aprox 550rwkw vl running 9.0@155 mph.
I'd be more inclined to question those figures than Powertune's - but you can't compare them straight up anyway, unless the VL also bogged, and was running 20" rims wearing low profile basic street tyres. 142mph in a full weight honest street spec GTR with a 2.6litre engine (with stock internals so probably not big rpm) is insane, anyone knocking the time or power figures really outta take stock for moment.
I just copied this from another post......
I just ran our NITTO R34 GTR at the drags on saturday at Willowbank.
Ran a 10.39@142mph on Hero 255/30R20 tyres, Tein Monoflex coilovers, OS88 gearbox, standard 05U rb26 with precision 7675 turbo making 845hp @ all four wheels.
1.77 60ft
4.69 330ft
6.9 1/8mile (107mph)
8.799 1000ft
10.39 1/4mile (142mph)
Slicks and auto vs Street tyres and manual... Thus why you can't compare times and mph
Edited by SimonR32
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
