  • Replies 60
Don't 3582 if its a daily. Will need plenty of supporting mods including Ecu.
It's a huge turbo compared to stock
I drove an unopened RB25 with a 3076 bolted up to the side and I thought that was hella laggy, can't imagine how laggy a 3582 would be lol...
nothing, nothing, nothing, (4500rpm) something, soemthing, (5000rpm) BAM LIGHT SWITCH ROCKET, rev limiter
What are you guys (those of you running highflowed/bigger turbos) running in terms of ECU? Have you just got a remap or are you running aftermarket ECU modules like Wolf3D or Microtech?
if you're going highflow and want to keep the stock injectors/afm etc.. and don't want crazy power.. just get a nistune or toshi to reflash your stock ECU (he uses some funky daughter board that's not nistune and solders it on)
I have Nov and Dec special.
Nistune Z32 ecu tune for std turbo $1100 include ecu and nistune board.
Nistune Z32 ecu tune for hiflow turbo only $1150 include ecu and nistune board.
This price only 4 cars.
R33 ecu tune is from $700
I hi flowed my 33 turbo a few years back and bolted it back up ran around 9-10 psi and car did not like it at all so I had to upgrade ecu,luckily enough the American dollar was crazy good at the time and I ended up getting a pfc delivered to my door for just under $1100.
Okay, so I pulled my intake apart this afternoon... Shaft play isn't overly bad, but it's definitely present. Gonna fabricate up a catch can, install it, clean the intake out and check the intake again in a few weeks and see if the oil is still present. My plan for upgrade (now I've researched it, I kinda wanna do it anyway) is to get Hypergear to highflow the turbo and install a NIStune daughter board to the ECU and tune it for 10psi boost. Should cost around $1700.
Mental note....you can't put a Nistune board in your R33 ECU. You have to get a Z32 or R32 ECU and use that. Z32 gives you VTC with no other hassles. R32 means you need to add a window switch to control the cams. Other option, as posted above, is Toshi funkying up your R33 ECU. But I'd tak him up on his Z32 Nistune option if I were you.
Does the Z32 ECU plug into the R33 harness or do you need to re-wire it?
Just get a std turbo rebuilt to std specs otherwise as your finding out the price goess up fast and the mod bug will bite you... Once you start you cant stop...
And if you cant stop with the mods youll find the nistune and hiflow wont be enough and your simple daily will turn into something else, im sure many people on here have found this to happen...
Keep it simple and things will stay simple and relatively cheap
Start to modify stuff and it wont stop and does get expensive and time consuming
Yeah I'm starting to see that. I don't wanna start throwing money at it if it's going to be an ongoing thing... Trying to save for bigger things (i.e house). Almost everywhere I've spoken to says they will highflow it as well as rebuild (hypergear included) so what if I get it installed, install a manual boost controller and just retard the boost to 7psi if it tries boost higher after the highflow.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
