  • Replies 60
Don't 3582 if its a daily. Will need plenty of supporting mods including Ecu.
It's a huge turbo compared to stock
I drove an unopened RB25 with a 3076 bolted up to the side and I thought that was hella laggy, can't imagine how laggy a 3582 would be lol...
nothing, nothing, nothing, (4500rpm) something, soemthing, (5000rpm) BAM LIGHT SWITCH ROCKET, rev limiter
What are you guys (those of you running highflowed/bigger turbos) running in terms of ECU? Have you just got a remap or are you running aftermarket ECU modules like Wolf3D or Microtech?
if you're going highflow and want to keep the stock injectors/afm etc.. and don't want crazy power.. just get a nistune or toshi to reflash your stock ECU (he uses some funky daughter board that's not nistune and solders it on)
I have Nov and Dec special.
Nistune Z32 ecu tune for std turbo $1100 include ecu and nistune board.
Nistune Z32 ecu tune for hiflow turbo only $1150 include ecu and nistune board.
This price only 4 cars.
R33 ecu tune is from $700
I hi flowed my 33 turbo a few years back and bolted it back up ran around 9-10 psi and car did not like it at all so I had to upgrade ecu,luckily enough the American dollar was crazy good at the time and I ended up getting a pfc delivered to my door for just under $1100.
Okay, so I pulled my intake apart this afternoon... Shaft play isn't overly bad, but it's definitely present. Gonna fabricate up a catch can, install it, clean the intake out and check the intake again in a few weeks and see if the oil is still present. My plan for upgrade (now I've researched it, I kinda wanna do it anyway) is to get Hypergear to highflow the turbo and install a NIStune daughter board to the ECU and tune it for 10psi boost. Should cost around $1700.
Mental note....you can't put a Nistune board in your R33 ECU. You have to get a Z32 or R32 ECU and use that. Z32 gives you VTC with no other hassles. R32 means you need to add a window switch to control the cams. Other option, as posted above, is Toshi funkying up your R33 ECU. But I'd tak him up on his Z32 Nistune option if I were you.
Does the Z32 ECU plug into the R33 harness or do you need to re-wire it?
Just get a std turbo rebuilt to std specs otherwise as your finding out the price goess up fast and the mod bug will bite you... Once you start you cant stop...
And if you cant stop with the mods youll find the nistune and hiflow wont be enough and your simple daily will turn into something else, im sure many people on here have found this to happen...
Keep it simple and things will stay simple and relatively cheap
Start to modify stuff and it wont stop and does get expensive and time consuming
Yeah I'm starting to see that. I don't wanna start throwing money at it if it's going to be an ongoing thing... Trying to save for bigger things (i.e house). Almost everywhere I've spoken to says they will highflow it as well as rebuild (hypergear included) so what if I get it installed, install a manual boost controller and just retard the boost to 7psi if it tries boost higher after the highflow.
    • This car has run before on this z32 ecu can get the part number for you, I have tried with no AFM it didn’t change anything, I compression tested today 140-150 across all 6 cylinders, also set fuel pressure to 43psi. The only weird thing was cylinder 1 plug was black and fouled other 5 cylinders were just wet with fuel. Spun cas by hand and confirmed injectors are clicking
    • Since you came here to ask for help, have you thought about answering our questions, that might help us lead you to why it was skipping, or have you given up on getting advice?
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
