Sorry to crash thread but i'm trying to find some quick answers without starting a new topic. I have an R33 GTS-T with a GCG Highflow turbo (XTRGTST). What power range could I excpect to get out of it?
http://www.gcg.com.au/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=337&category_id=34&option=com_virtuemart&Itemid=101
ok so i cant wait for the ol' 30 to be built, i have got my walbro e85 fuel pump and my injectors will be here next week then its off to Jez to get this happening
should all be done in the next few weeks so il post up the results...
Has jez touched you your car yet?
Yes he did....it felt good he said
For some reason it was running out of fuel, wasn't the injectors coz they were at 75%,
Made about 360ish at wheels.....we did see more then 370 though
Gotta run a few tanks of ethanol through it, change the filters/clean the fuel filter sock and go back to make sure everything is 100%
Huge difference in torque and thrust lol
  • 1 year later...
What tends to break on these at this power level? Do they normally just spin a big end or do they throw a rod out the side of the block haha?
Im running a 35r at the moment with just over 500hp and was thinking about changing to e85 for a bit more but a bit unsure if its going to hold
up to the extra power or not and what will break if it doesnt.
e85 would allow you to run a much smaller turbo for similar power levels, making the car much more responsive and faster overall.
Who knows what will break and when, but at least there will be no DET which is what usually kills motors, built or stock.
Ethanol will give you more torque, but the way the power is released during the stroke should help with longevity, and your exhaust temps should be around 200c lower also. The only real downside is less K's to the tank.
So do you personally think it's worth pulling the motor out just to do the same oiling mods that you did and chucking in some new head studs and head gasket?
Haha your recent results Simon was what inspired me to put mine on e85
If you are prepared to build the motor but want to try and get away without you can always try.
Whilst the motor is good for the power in described trim you should bear in mind that the longevity of the motor is also largely dependent on condition and the life up to that point. Much like tests on SR20s, lots of people kill them at 200kw and then others have tested them to 400.
Be it myself I would stay within the known constraints but would boost it till it blows. However I would be prepared to replace the motor should it grenade.
GL and keep up posted :)
Yeah i have the mindset that I'll have to build the motor eventually and to be honest the car really doesn't see a real hard life. Simon you did oil pump gears and bigger sump if i remember correctly? Did you change these yourself?
  • 2 months later...
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
