Sorry to crash thread but i'm trying to find some quick answers without starting a new topic. I have an R33 GTS-T with a GCG Highflow turbo (XTRGTST). What power range could I excpect to get out of it?
http://www.gcg.com.au/index.php?page=shop.product_details&flypage=flypage.tpl&product_id=337&category_id=34&option=com_virtuemart&Itemid=101
ok so i cant wait for the ol' 30 to be built, i have got my walbro e85 fuel pump and my injectors will be here next week then its off to Jez to get this happening
should all be done in the next few weeks so il post up the results...
Has jez touched you your car yet?
Yes he did....it felt good he said
For some reason it was running out of fuel, wasn't the injectors coz they were at 75%,
Made about 360ish at wheels.....we did see more then 370 though
Gotta run a few tanks of ethanol through it, change the filters/clean the fuel filter sock and go back to make sure everything is 100%
Huge difference in torque and thrust lol
  • 1 year later...
What tends to break on these at this power level? Do they normally just spin a big end or do they throw a rod out the side of the block haha?
Im running a 35r at the moment with just over 500hp and was thinking about changing to e85 for a bit more but a bit unsure if its going to hold
up to the extra power or not and what will break if it doesnt.
e85 would allow you to run a much smaller turbo for similar power levels, making the car much more responsive and faster overall.
Who knows what will break and when, but at least there will be no DET which is what usually kills motors, built or stock.
Ethanol will give you more torque, but the way the power is released during the stroke should help with longevity, and your exhaust temps should be around 200c lower also. The only real downside is less K's to the tank.
So do you personally think it's worth pulling the motor out just to do the same oiling mods that you did and chucking in some new head studs and head gasket?
Haha your recent results Simon was what inspired me to put mine on e85
If you are prepared to build the motor but want to try and get away without you can always try.
Whilst the motor is good for the power in described trim you should bear in mind that the longevity of the motor is also largely dependent on condition and the life up to that point. Much like tests on SR20s, lots of people kill them at 200kw and then others have tested them to 400.
Be it myself I would stay within the known constraints but would boost it till it blows. However I would be prepared to replace the motor should it grenade.
GL and keep up posted :)
Yeah i have the mindset that I'll have to build the motor eventually and to be honest the car really doesn't see a real hard life. Simon you did oil pump gears and bigger sump if i remember correctly? Did you change these yourself?
  • 2 months later...
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
    • Ok so i will NEED to have this sensor anyway even with Nistune (or standalone ECU) https://justjap.com/products/genuine-nissan-boost-pressure-sensor-evap-control-system-fits-nissan-r34-skyline-c34-nm35-stagea-pnt30-x-trail-rb25det-vq25det-sr20vet?currency=AUD&srsltid=AfmBOoqfxX48bW9bEwH62orcNhtBfp7ekAL0C9Ca89ySFGUiBzXfXeze Is this the correct one? And this is only thing i need? No other "things" connected to the sensor or something? I do have the wiring.
