Just to update this one, the new owner of the original car in question has been in touch, and is now planning to take SAG to court over it.
wouldnt happen to be the newspapers contact would it?
  • 4 weeks later...
Guys, this thread has been a real eye opener. I'm already a naturally skeptic person, now it's going to be hard to trust any car on the market.
I'm currently after an r34 GTR vspec 2, just waiting on finance approval, but i wont be going anywhere near dealers like this. Its just crazy.
We should keep this thread going with any additional info. Things to look out for for the novice buyer, cars to avoid, specific things to request from seller like what certs, documentation, when to turn away if a particular doco cant be presented. Websites that can assist in the validation of a car. Ive already taken note of every helpful link in this thread, trusted importers, helpful information, but the more info we have, the less chance people will make a mistake when buying a car.
Thank you all.
I'll be in contact with a few Importers shortly.
Thank you all.
actually u just need to speak to one guy... iron chef kristian... :yes: feel free to bust his balls to find your ideal car... ;)
Just read this thread and got paranoid about the 33 GTR i've been looking at.
Is there an easy way to track a cars Japanese history and old import paperwork?
The car I saw has a nismo dash, so wanna know when it got replaced and therefore the real kms on the chassis.
The dash had 120k on and the condition of the car is immaculate..
Looks better than a couple of 80k gtrs i have seen and drives very well.
It is a 95 GTR V-spec.
I have flicked iron chef an email to see if he can help.
Any thoughts?
Look for a guy on here called Dodgyimports. I believe he runs a service that will give you some good info.
Since your vehicle hit the shores of Aus it's anyones guess though :unsure:
Correct.
Thank you all.
'Tis hard enough to trust spam
Was a nice grade 4 gtr that went through the auctions recently with 194k on the clock
Sold for 2.2m
Well be interesting when it comes up for sale
.. advertised done 49,000 genuine km mint mint mint condition no scratches or damage history 1 owner like brand new........
Just used a company called JOC (Japanese odometer check) on fb and internet.
Payed them a small fee and they traced the pre-import registration via the official Japanese vehicle department.
Quick and easy way to see recorded kms when it registered/re-registered in japan.
They get the paperwork and translate the page into english too!
Highly recommended!
Probably a must for a Japanese import especially after reading this particular thread!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
