Mate has a R32 GTR who's been stuffed around by doggy workshops to the point he has no GTR to drive.
He's looking at spending up to $20k on an engine or a rebuild, in all labour etc. Obviously looking for supreme reliability so no second hand parts unless they are obviously just as good as new. Would consider a full engine but ones like CRD's is well over the budget or need.
He only has a standard engine, so will need computer, fuel system, turbo's etc.
Suggestions?
https://www.sau.com.au/forums/topic/413703-20k-for-newrebuilt-engine-options/
  • Replies 61
Hey John - check this site for a package http://www.lewisengi...category9_1.htm
Saw it on a similar thread recently.
Maybe the $13k package. That will have left over bucks for aftermarket ECU, fuel pump etc..
Plus the out/in costs and consumables
Just a thought.
This guy does good work - would post it to you as a short block or put a head on (for extra) if you want:
http://www.hytecheng....nz/p/sale.html
Actually the Lewis Engines might be easier for you if the quality is there.
I would think he would want a australian (prob Can/Syd/Melb) builder with a strong rep for everyday engines. Prefer if the one place could do everything, drop car off, pick car up when done & tuned.
Or just give a listing of the parts and work cost that needs doing and he can source a builder himself.
The biggest issue with engine builders is the time they take, i have used a few different builders and most have taken up to 4 months to get the engine back.
Worth the wait hen u see theresults but still. Long time.
See if u can get an exchange engine i fthe wait is an issue
^^ See above.
Too often i see guys get screwed around on workshops who decide to take up 5-6 big builds at a time and work on each one when they have some spare time.
Its understandable that projects like this take time but some workshops over do it. Heck ive had a forged rebuild "drive in drive out" done in 3 weeks including modifications to the head, all machining, upgrade to my fuel system (pump, injectors etc). Most people are lucky if they get the same in 3 months !
I remember speaking to the owner of Lewis engines and at the time he said he can have the motor turned over in 3 weeks. Just ask him how busy he is. But yes workshops that take months coz they deliberately take on to much are f tards!
If your mate doesn't want to get stuffed around more I wouldn't recommend this builder.
Why's that? I am planning to get in touch with them sometime in the new year for a motor.. PM me if you don't want to say in public
Just a thought.
-7 garrets @ 21psi = 370rwkw
surely thats a typo
although its possible on e85
Edited by usmair
surely thats a typo
Probably mixed up the -5's and -7's
-7 garretts @ 21psi 370 rwkw
tomei ARMS twins @14psi 330rwkw
single TO4Z garrett @18 psi 390 rwkw.
-5 garretts @21 psi 340awkw.
NOTE: I haven't used LEWIS. So it's not an endorsement, just seemed to fit the requirement.
CRD did my build and yeah over $20k. I'm extremely happy with the result.
Not so happy with other business issue things and elapsed time for the rebuild. But hey - you get that and you just have to work through it.
330awkws at 18 psi on -7's (ESP tuned)
Could ask ESP (Qbyn) to get a price, timframe and make a judgement call if your comfortable.
I haven't had one built there either (like most others they would subbie some of the work), however I get them to do all my other work.
Reasonable on price and have met all their commitments to me.
Was a differen't story a year or so ago. They just overbooked and under deliverd.
Changes in the shop staff has made a big difference in my opinion.
Not had a bad experience since. *touch wood*
About to go spend another $5k with them.
Good thread to read, and when spending 20k on an engine, have a few good talks to your tuner. No half an hour later he has a 20k job sitting on his lap.
Talk to the guy building the engine, ask how many Rb's he's built. Or if he's been rebuilding ford's forever..
The most helpful guy will be the bloke actually rebuilding it. *not the guy at the front desk selling you shit*
Do yourself a favour go direct to the guy your dealing with, don't get a workshop who gives the job to someone else. It will take longer in the end. and you may not *not saying you won't* be happy with the end result.
Just my few cents from experience. worth the hassle if you want quality results "you" are happy with.
Thanks for the replies. I'll let him decide where exactly he goes.
More after suggestions for the build in the way of parts and the work needed. The built engine of "lewis" for 13K was something that was good to read.
I'm sure people have spent around this amount for a rebuilt/new engine, how did it go, what would you do differently?
fark... i get the shits over 2 weeks... never Waited more than 3.
If I could do it again, I'd seriously think about running a motor with stock internals. Beat the crap out of it, blow it up, rinse, repeat.
Dealing with engine builders generally sucks, and people generally overbuild motors for no good reason. What do you truly get with a built motor? piece of mind?
Edited by black bnr32
    • 100% the factory sender is tapered, that is how it seals (well, that and teflon paste or tape)
    • Thanks folks - I've saved a few links and I'll have to think of potential cable/adapters/buying fittings. First step will be seeing if I can turn the curren abortion of a port into something usable, then get all BSPT'y on it. I did attempt to look at the OEM sender male end to see if it IS tapered because as mentioned you should be able to tell by looking at it... well, I don't know if I can. If I had to guess it looks like *maybe* 0.25 of a mm skinnier at the bottom of the thread compared to where the thread starts. So if it is tapered it's pretty slight - Or all the examples of BSPT vs BSPP are exaggerated for effect in their taper size.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
