I'm finding it surprisingly hard to find United E85 locations in Sydney . I followed one link back to United and traced three servos ie Blaxland Rozelle and Drumoyne (Sp ?) . I did see mention of a fourth but don't know where that one is .
These three are pointless if you live on the southern outskirts of Sydney because they are too far away or awkward to et to .
Can someone tell me where the fourth United E85 source is and if theres any down Wollongong way , even thats a bit far really .
I was hoping to get a higher blend than EFlex E70 reasonably close because the higher content means less to make my blends up with .
Any help appreciated , cheers Adrian .
Bloody Dee Why , what've United got against us southerners ?
Well if you're going to make your own brews the higher the ethanol content the better because its less to add and less base stock to try to ignore .
Looks like winter grade EFlex will have to do , cheers A .
Buy it by the drums if you're mixing at home?
  • 7 months later...
Are there any more United E85 service stations that have opened this year in Sydney ? Minto is still the closest and for whatever reason my 33 likes it better than EFlex . The other night I dumped a 1/4 tank of Minto85 on top of 3/4s of EFlex and my car seems to run smoother and is getting a few more MPG .
We've got EFlex nearby but no local United 85 .
Cheers A .
Well , people still talk about wheels in inches and boost in pounds but no I think in terms of litres per hundred km and I'd love to get 10/100 . MPG is just quicker to type .
When this tank full gets low I'll try 50 50 United 85 and Caltex E70 . Thinking about it I was running United 85 before the ViPec and tune so maybe my engine likes it better because it was getting better consumption round town then with the PFC and Z32 MAF . You'd think E70 having more "petrol" in it would get better mileage than E85 though the Americans suspect that what the oil co's put into some ethanol blends isn't real flash in the "petrol" component .
Cheers A .
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
