I still can't wrap my head around brand new OEM coils for $250.. when they're like $100+ for each coil from most traders
100% genuine, genuine part numbers and packaging. From the states, same story as bob.
I couldnt believe the price also, hes a good person to deal with, very helpful and check his feedback
I'm a tad hesistant on buying them, but you guys are saying they work
Well so was i for the price, but he says they come from a dealer in the states closed down or something like that.
For me the thing that done it was, his communication and have a look at his feedback, nearly 1000 @ 100% positive, nothing wrong with that!
Edited by Bw33zy
Bob, so did you buy it from the same link too?
http://www.ebay.com....1#ht_693wt_1271
I'm really tempted to buy them now to replace my homo mismatched Yellow Jackets
Just checked - and no was another Aussie ebayer and i paid $400 and he is not selling now so maybe he was a reseller - was over a year ago and they are still working fine!
  • 4 years later...
On 11/22/2012 at 0:14 PM, KiwiRS4T said:
They were over $1000 a set from Nissan!
I bought an ebay set and they look genuine and seem to work ok. I heard they came from a bankrupted Nissan dealer in the US though why they would have huge stocks of them I don't know. I hope they are not fake but are working so far at 20psi and 280kw. See what happens with a bit more power.
On another note a Stagea owner says his Yellowjackets broke down after 18 months!
Yay revive old post because I used the search function :P
im considering the Fuji spark coils because I can actually afford them. But I have no clue what they're like and can only find old reviews from like 5 years ago.
Or should I get yellow jacket?
its kinda pushing it for yellow jackets and then split fires which I'd love are just out of the picture currently
not sure if I should risk it or not
I suggest you research wisely on what I have highlighted.
yeah search function will reveal most opinions on said highlighted product
i see more and more people selling used splitfirfes on fb pages, i would trust them over the cheaper options.
Edited by GH05T
Right... what exactly do you mean by that? Or is there anything in particular you are referring to?
I took a look on Facebook and couldn't find any posts unfortunately
I have yellowjackets and they work fine [emoji14]
But my engine is standard, standard boost.
If you're going to push it, Splitfire or new OEM.
I've just got a standard 25RS Four Stagea, RB25DE NEO. So it's not exactly a high performing car haha.
I won't need expensive coils I take it
Try using Google for searching. Facebook isn't the place for info on this type of thing. I'll spell it out for you. Spitfire and oem is the way to go for standard style coilpacks. All the other brightly coloured ones have sketchy reputations. These days people convert to ls1/2 coils and Toyota yaris, Audi r8 amongst others. Just remember you get what you pay for. If you need more info than that, GOOGLE[emoji6]
Yellow jacket are probably only about $100 cheaper. When I used google the first 10 results were all SAU. I'll do some research on LS coils
Cheers.
Ls coils are not direct fit. Oem or split fire is my recommendation. Whichever you can get cheaper or easier.
Figured that, not too sure whether I should just replace the shot one or go and buy a whole set. As I don't know if I want to replace one then have another one go down the road lol
I'm leaning towards splitfire but don't really have the money for a full set
I'd suggest selling the car cause you obviously can't afford the repair bills on it
Okay so I probably worded it wrong, I don't have money set aside for coils. Doesn't mean I don't have the money for them, I do, lol.
If that's the case and money is scarce, gap the plugs down to 0.6mm and see if that fixes it for now and keep a look out on eBay Gumtree forums for some used coils to mix and match to make a full set. I bought an oem set off ebay a year ago for $10 as spares, they also came with a loom. I tested them just to see if they where any good and they where. Good luck.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
    • It sounds like you want what the Toyota Landcruisers have for their roof racks. Wanna know what you end up with? Rust holes in the roof, and water everywhere...
    • Discovered today that if I select reverse first and take my foot off the brake, then select drive, the drive indicator light works and so does the tiptronic gear indicator.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Does anyone here have any ideas?   Cheers guys
