Are you sure the rotors are on the right way? Reason i asked is because i have the same rotors and mine are the other way, i double checked it seems like the vains on the pmu scr pro rotors follow the direction of the slids...
i though the vain is suppose to go the rear? it goes from the center of the rotor then out or its the other way?
Air should be coming from center of rotor to outer rotor
Edited by ichi-go
that dosnt make sence to my brain, surly it should be sweeping outwards not draggin inwards?
I would tend to agree by looking at the design. Disc designers are a lot smarter than me however...
I guess it must act as a vacuum by creating a low pressure zone outside the vanes which draws the hot air out from the centre of the disc outwards. Makes sense in that it evacuates the hot air and dust away from the centre of the disc.
the vanes would work exactly how a turbo works
sucks in cool air from the centre, and propels it using centripetal acceleration (flings it outwards)
having them curved just helps draw the air through the disc
Vanes are the ones on the inside that pump air. They should sweep backwards.
Grooves are on the outside and remove pad dust etc. It doesnt matter which way they go.
You orientate the rotor for the vanes, not the grooves.
As an aside the Project Mu rotors dont have proper vanes anyway so this stuff doesnt matter very much.
Flat out getting this car finished guys, most fluids are in and 50% of interior left to put back in
Photos will come as soon as I can
NEED SOME HELP PLEASE GUYS.......CAN ANYONE HELP WITH FACTORY NISSAN PLACEMENT/MEASUREMENTS OF ALL THE BADGES/EMBLEMS???
NEED TO FIGURE IT OUT THIS WEEK!!!
Cheers
Insane work, well done... Going to be so bad driving on the road for the first time, I bet you will be able to hear every single bit of sand and dirt hitting the undercarriage :(
Thanks Simon, maybe...but there will be so many other epic noises!
Well I think we can safely say thread is delivering on title as promised...
How many tooth brushes have you gone through to get it to this state???? :) How on earth did you get the plugs, wiring, hose clamps so clean... man!
Love the dedication well done.
Cheers Paul. Mate I am well and truly over cleaning I can tell you that.
This car should not be driven. It should be stored in a garage that is cleaner than a laboratory
Ha Bryce, I don't have that level of will power!! I NEED to drive it.
Coming along nicely love checking in and seeing the progress every week. Seriously though buy another one to drive and wrap this one up to neat to ruin.
Thanks mate. With everything I have learnt I think I will need to buy another one to restore and not drive, one day....
robbie will you ever sell it haha?
Don't think so but you never know right
great thread.
Cheers Paul
Looks too good to take out on the street now :yes: Top work!
Thanks mate. Knees will buckle haha
Jus finished reading this thread from page 1. Superb job so far, cant wait to see this through.
Nice. It's nearly there, just need to get the time to get photos up!
Nice build Robbie, can't wait to see the before and after picture. Yay! Can't really wait to see the final output. Keep up the good work and Goodluck! Will follow this thread. :no:
Cheers! Shouldn't be long now mate. I really wish I had the foresight to take more photos of the car before ripping into it...
Power output figure will be interesting
Rear Nismo bushes and rest of OEM front ball joints in
Billet spacer installed
Making up AFM adaptors
Brand new OEM BM57 BMC and stopper done
P/steer in and belts on
Cooler top brackets in
Fitting up radiator
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
