So lately I have noticed that my car has been using a bit of coolant.
Every couple of times I use it I just throw a bit of water in the radiator.
Today I decided to find out wtf is going on and I think I have figured it out.
My overflow bottle is hidden behind a custom panel I had made up so I havnt been able to check it.
Today I removed the panel and had a look and the overflow was full to the top with green coolant (a lot greener than the coolant in the radiator as I have been watering that down).
Its like when it gets hot it can overflow into the bottle but it cant get back...
I took the line off and blew through it and it isnt blocked or anything....
Any ideas?
can just be a crap seal on the radiator cap, not the centre spring but the top of the neck to the cap. I had this on mine, with a munted neck the cap was still holding pressure but it was easier to suck air back into the neck than to bring water back through. Bit of silastic and all was nice again.
Needs new head gasket and ARP bolts.
Smell the bubbles in the radiator, if they smell like petrol you are ripping the head off.
yep agree
and this 2
start of small and work your way up! will be a process of illimination
Agree with this.
Coolant heats up, takes easiest path into overflow.
Cools back down, leak somewhere lets air get sucked in to fill the gaps as that is easier than sucking the coolant back up from the overflow.
Had this problem on my old engine. Turned out the head gasket had a tiny leak, If I wasn't paranoid about my car I wouldn't have noticed. Not too hard a job to replace.
Does the coolant system stay pressurised after the car is left over night? and does the top hose feel rock hard when warm?
well i was running a 1.3 bar cap... swapped it today to a 0.9 bar one.
I also bought one of those chemical combustion leak tester thingos but it came up all clear...lll see how it goes with the new cap.
Agree with this.
^^ What he says is as good a place as any to start. Renew overflow hose (if you haven't already) from radiator to o/flow bottle & see how you go.
Cheers GW
Dang! Same thing happens to me.
Overfill bottle fill but radiator keeps on emptying. Think I too have a leaking head gasket from boiling the car last year.
Any consequences of having a leaking head gasket? I might just leave it and keep filling the radiator....no monies
I drove my VQ for a year like that, without realising it was the head gasket. It let go in a big way on the dyno during a tune.
Get a carbon test done on the coolant, it should show up any combustion bubbles making their way into the cooling system.
yeah I suspected my head gasket, but the combustion gas test came up all clear.... my mates S14 has been running like shit and we couldnt figure it out so I did the test on his and the dye changed colour straight away which means he has headgasket issues.
Its an awesome bit of kit... I got mine from repco for $130, just ring and make sure they have got one first as lots of places were out of stock when I was looking for one.
Here is how it works for anyone who doesnt know....
Edited by arrydjay
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
