So lately I have noticed that my car has been using a bit of coolant.
Every couple of times I use it I just throw a bit of water in the radiator.
Today I decided to find out wtf is going on and I think I have figured it out.
My overflow bottle is hidden behind a custom panel I had made up so I havnt been able to check it.
Today I removed the panel and had a look and the overflow was full to the top with green coolant (a lot greener than the coolant in the radiator as I have been watering that down).
Its like when it gets hot it can overflow into the bottle but it cant get back...
I took the line off and blew through it and it isnt blocked or anything....
Any ideas?
can just be a crap seal on the radiator cap, not the centre spring but the top of the neck to the cap. I had this on mine, with a munted neck the cap was still holding pressure but it was easier to suck air back into the neck than to bring water back through. Bit of silastic and all was nice again.
Needs new head gasket and ARP bolts.
Smell the bubbles in the radiator, if they smell like petrol you are ripping the head off.
yep agree
and this 2
start of small and work your way up! will be a process of illimination
Agree with this.
Coolant heats up, takes easiest path into overflow.
Cools back down, leak somewhere lets air get sucked in to fill the gaps as that is easier than sucking the coolant back up from the overflow.
Had this problem on my old engine. Turned out the head gasket had a tiny leak, If I wasn't paranoid about my car I wouldn't have noticed. Not too hard a job to replace.
Does the coolant system stay pressurised after the car is left over night? and does the top hose feel rock hard when warm?
well i was running a 1.3 bar cap... swapped it today to a 0.9 bar one.
I also bought one of those chemical combustion leak tester thingos but it came up all clear...lll see how it goes with the new cap.
Agree with this.
^^ What he says is as good a place as any to start. Renew overflow hose (if you haven't already) from radiator to o/flow bottle & see how you go.
Cheers GW
Dang! Same thing happens to me.
Overfill bottle fill but radiator keeps on emptying. Think I too have a leaking head gasket from boiling the car last year.
Any consequences of having a leaking head gasket? I might just leave it and keep filling the radiator....no monies
I drove my VQ for a year like that, without realising it was the head gasket. It let go in a big way on the dyno during a tune.
Get a carbon test done on the coolant, it should show up any combustion bubbles making their way into the cooling system.
yeah I suspected my head gasket, but the combustion gas test came up all clear.... my mates S14 has been running like shit and we couldnt figure it out so I did the test on his and the dye changed colour straight away which means he has headgasket issues.
Its an awesome bit of kit... I got mine from repco for $130, just ring and make sure they have got one first as lots of places were out of stock when I was looking for one.
Here is how it works for anyone who doesnt know....
Edited by arrydjay
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
    • Sounds good. Provided the panel is flat/level I'd be happy to start the painting process.  While you are learning, for sure you could do this. Its only paint, you can always sand it all back and start again. Its only your time and money on materials, but while you're learning, really its time and money spent on your education.  Once you know how to do this bodywork and painting, you won't want to waste your time and money on frivolous activities lol.
    • Yep I will use a guide coat after putting filler, I will do it on the whole panel as I'm a beginner so chances I've made quite a few errors. In that photo, I think that was a low spot, I just for example said to pretend it's flat but I will put filler + guide coat after to assess where I'm at. Yep with that picture, the panel is wet as it rained when I took the photo. But all those scratches are completely smooth, I went over it with 240 grit and can't feel it, even with my nail digging into it. I was legit thinking to buy a 2k can and spray primer to see how it turns out but then thought to myself it's going to be a mess doing it haha. Good mention there. Thanks for all that info I think I know what to do next.
    • Prior to laying down the primer, you need to make sure the surface is completely level. For example, based on this picture, I strongly suspect that the areas marked in blue are higher then the area marked in green.  If you spray primer over this entire area, then paint and clear it, the finished result will 100% show the low area. It will stick out like dogs balls. Unfortunately the paint won't magically level out the low areas as you lay it down.  Without seeing it in person, I expect that the green area will need to be filled, then use a guide coat and check that the entire repair area is level with a large sanding block.  With this picture, are you saying that even though you can see the scratches, the panel is in fact completely smooth and flat? If this is the case sure you could prep and paint it as it is.     The picture with the paint you described as blistering, it's hard for me to comment on from the photo alone. It looks like the panel is wet? Dunno, looks strange. Does the panel feel as smooth as glass when you run your hand over it? **** Going back to your question again, generally you would only sand the primer if you made a mistake while laying down the primer.  If the panel is prepped properly and you lay the primer down properly, you should not need to sand the primer.  This wouldn't work - Don't prep the panel. Spray primer and see how it turns out. Sand the areas where the issues appear. Spray more primer and see how it turns out. Sand the areas....... Yeah you'd go round and round in circles getting no where.
