hey guys :)
i got an r34 gtr
i just bought a trial titan tryforce 3' catback titanium.
i have a venom 4'' cat and trust front pipes
since fitting it last night, sounds amazing!!!
BUT!!!!!
has an awesome drone from 2700-3100rpm.
has anybody got a titaium exhaust and had the same issue?
its just got a resonator and a cannon muffler, ive heard the idea of stuffing your spare wheel cavity with sound deadening or blankets and stuff like that to stop the drone coming into the cabin, but didnt really work LOL!!
once again it sounds great but annoys me that inbetween those rpm's especially on the freeway when your cruising at 110 and it sits on 3000. :verymad:
anybody got any suggestions :no:
https://www.sau.com.au/forums/topic/414728-titanium-exhaust-drone/
  • Replies 83
Step 1: sell the titanium exhaust and pocket HEAPS
Step 2: buy a quieter exhaust and have HEAPS of change
Please don't wreck the Ti exhaust by adding some botch job muffler onto it.. Not sure if you realised but DVS JEZ was joking. Stick welding and oxy cutting are probably the messiest way to do anything, and you probably couldn't even do it with titanium.
A decent muffler will weigh more than the entire exhaust TBH.
And of course it'll make it quiet.
If you still want "loud"-ish and less drone you need to sell the Ti system, you'll never achieve both as they always have wafer thin mufflers.
Do what GTScotT said? I had to get rid of my Ti system, couldnt afford a Mine's VX Silence Ti (for the weight) so I got a stainless system, lost 80hp because I went smaller diameter.
But, for the money I sold the Ti system for, I bought the Stainless Fujitsubo, got the Ti removed, new exhaust fitted, dyno tune and pocketted a $150.
Very interested in power/exhaust size ratio. What were you making before you lost 80hp??
How on earth would that help?
noise not only exits the end of the exhaust pipe but also resonates thru the pipe itself, exhaust wrap would act as a silencer as well as keeping up exhaust gas velocity
    • A few suggestions: Do you have the option of retarding your exhaust cam gear to bring the power band over to the left? VCT would be turned off after you make peak torque, you see the power/torque will decay faster with it left on all the way to the limiter Once VCT is turned off, you'll find the motor will take a bit more timing being ramped in Send its mum, more boost! Of course, depends on your exhaust pressure.
    • Tow a boat... people won't know wtf is going on 🤣
    • I was back on the dyno again yesterday after completely revamping my methanol injection system. I was making 440kw at 19psi. Great, this is more then I was making last summer with my old meth system at that pressure, and I figured it would be smooth sailing up to 30+psi. We continued increasing from there and by 25psi, I had only hit 455kw. Dyno sadly lost utility power at this point and I left. We seemed to be on course to hit the same power wall as last summer (477kw@27psi). This is a built RB25 S1 stroked to a 2.8. Built and ported head with Kelford 272/262 cams. Precision 6466 Turbo. Tuner last year believed the power wall is a mix of RPM limitations (Hydro lifters/Limit set at 7600RPM) and fueling. With my new meth system, we're seeing zero knock now but it still won't go up.  What else can I do at this point? Here's my train of thought.  - It's clear from the dyno graph that I would easily make power to 8500+RPM but I'm limited to 7600RPM. I could risk increasing my limiter, but hydro lifters have me worried. What are my options here besides going NEO head or solid lifter conversion? I'm rocking a 1.05AR turbine on my 6466. Would dropping down to a .84 help shift that power down in anyway? - We're only seeing roughly a 30kw difference at the top end with VCT on or off. Is this normal? I want to confirm VCT is working properly. - Should I look into other cam options?  - Should I just keep increasing boost and see if she wakes up later on? I would expect to hit 600rwkw around 35psi with my 6466.
    • First thought is to use a ram mount (to hold the ipad) + windscreen suction mount. The arms on the ram mount can be as long as you like, should be able to position the ipad pretty well with that setup.
