Yes Joey, drag slips, its the only way to be sure, I'll race you for beer (no more little bloody donuts, bastards).
You will though need to spot me 5.5 seconds though.
I'm guessing you might run a 10.5ish where I might run a 16ish
Come on, my 5 has at most an astounding 80 to 90 killerwasps at the back wheels.
Put It this way, my old RWD boat on old drag radials and 380kw got a 11.008, I'm sure there's a 10.5 in yours.
The box should be fine for the first couple of runs, it might sound a bit like industrial exhaust fan after that though.
In all honesty if you take off easy and don't shift to hard the box should be fine, I believe its the drag radials and big launches on the sticky stip that eats the 1-3 gears.
Ill give you 4.9 seconds then, with a 6 pack of Crownies on the line.
EDIT: First gear?, with your torque the only time you will use first gear is in the lanes before the water box
Righto,
take this as you will, i consider that engine capacity, cams, fuel makes it a "similar" comparison
So same dyno
Both set ups have
2.6L
both have standard compression from memory
similar drop in cams
high ethenol content fuel
Both have large sufficient exhaust, ignition and fuel setups
Mine is the orange/red line
-5 line is black
To be fair, that -5 result im comparing against wasnt the most responsive run out of them all. But that particular result did flatten out alot after 5200rpm and my curve was still fatter
I dont know if i want to test the waters.. maybe when i get a stronger box.
I would have just got the thing on the road and i dont feel like spending more $$$ to keep driving it haha
Oh yup similar looking results to what I got just bait higher because of the ethanol.
I might stick with the -5's until i upgrade my injectors/gearbox and then go with a 8374 1.05 A/R as my bottom end has been built to withstand hell.
and I hear you about popping the standard box. Why I haven't run mine yet.
It's interesting to note that there is very minimal change in power between E45 and E85 on our boost levels. It's only an extra safety margin..
I'll be running 50/50 as a more common everyday mix
Lol, lies, I see lies :P
You can't really compair single v twin cause to many veriables like intake and dump pipes etc, dump pipes are one of the biggest issues with turbos and it's hard to get wrong on a single, especially if you have a external gate, but very very easy to get wrong on factory mount twins
Even cam timing makes a difference
So it really comes down to personal preference and what you want from your car
Haha, maybe, doubtful but maybe, but twins will get you there quicker :P
Take matty from WA's experience. Twin -5's on a 3.0 and went to a 8374/0.92 internally gate single. The EFR was back to peak boost levels in a 1/3rd of the time the twins took (Motec logs), made more power everywhere also.
However, it would be interesting to compare something like the 8374 EFR to say twin 6258 EFR's.
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
