  • 4 weeks later...
Finally made a bit of time to work on the car today. Only a small job but it's something ticked off (hopefully....).  I may still have to modify it which is the disadvantage of not doing it while the motor is in the engine bay. Lots easier to work on however!
My TIG welds are a bit iffy, can tell I haven't done much welding over the last 12 months. Relatively happy with how it turned out, I just hope it works once I plonk it in the car!
20220327_182437.thumb.jpg.bb1d3627aab80b284cb658c6f2748a0b.jpg20220327_190057.thumb.jpg.d8c58ef41ed3cb9b6d30728a430bacc5.jpg
  • Like 7
Engine is off the engine stand and onto my k-frame trolley. Works a treat!  So easy to move it around the shed. Once I finish what needs to be done to the gearbox I can bolt it to the engine and finish my little trailing jack dolley that supports the end of the gearbox and helps get the angles right for reinstallation.
  • Like 2
On 29/03/2022 at 9:30 PM, Dose Pipe Sutututu said:
Sexual manifold, dat split to the seat of the gate
Yeah its purdy. Bloody New Zealanders know how to make shit (as do plenty of Aussies).  NZ plays a very big part in my motor for no deliberate reason- sump, inlet manifold,  exhaust manifold, rocker cover fittings, plus some other little bits.
Turbo oil drain fits around the engine mount which is sweet!  Was a touch worried my measurements may be off but all good.
  • Like 3
i like that turbo drain, where did you get that one mate?
The flex pipe section is from Aeroflow, the stainless is just 19mm (3/4”) stainless, 2 AN10 stainless weld on fittings welded to each end of the stainless tube, 45 degree swivel fitting onto the block adapter and then an Aeroflow bolt on fitting to the turbo plus associated AN fittings to join it all together!  So in other words it’s a handful of random bits and pieces with a bit of welding, bending and head scratching to make it all come together!
  • Like 1
I’ll be firing up the welder I like that better than the braided steel drain line. Not to mention I’m only 10an a little small for turbo drain.
Go the Kiwi's ;) that is the same style manifold i have (same company as well) and it holds boost mint :)
Sweet, good to hear!
As much as we all love to hang shit on the Kiwis I do love them! Some amazing fabricators and tradespeople over there and God do they love thrashing cars!
I've travelled to NZ itself multiple times and travelled with a few Kiwis overseas and had a ball with them. They're similar to Aussies but wierder! 😂😂
  • Like 1
yes GIF
  • Haha 2
On 06/04/2022 at 4:07 PM, Old man 32 GTR said:
Mate, that is coming up a treat, very clean.
what gearbox did you end up going with? You were looking a gearset options weren’t you?
Cheers mate. Unfortunately its a long time between treats...
Ended up sticking with the Speedtek gearset despite much (understandable) pressurenot to. Interesting to note that despite all the negativity around them, they really seem to be kicking goals at the moment. They're pumping out some fairly diverse products now.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
    • I didn't actually try it at the time but a Launch X431 with the appropriate software licenses/upsell will have the ABS bleed function. The Consult II you can still find some old sets of equipment but they're really, really expensive:
    • Well I'll start by saying I'm not an engineer. I am going to go with the KiwiCNC ones.  They are made of 7050 alloy have good fillets and radius.  The material alone is in the order of double the strength and fatigue resistance - Those bolts, once torqued correctly place most of the load at the flat face of the mating surface - the 'stretch' you're talking about through torqueing them up would be far more than the extra stretch 'load' placed on them from a steering input or bump. (in my opinion) so I doubt they would flinch.    - but again "not an engineer".      oh and I don't think stitch welding 7050 is a good idea, likely just weaken the material (from what I read)
