Anyway........... :ermm:
I think we all got a bit carried away for a while there.
I assume that the point of this thread is just to make suggestions on "Where to get your Skyline serviced" so here are my suggestions (take them or leave them):
1. Extreme Street Performance
2. Trojan Motorsport
3. Techworkz Automotive
These are the shops that have looked after me many times in the past and in my opinion are the only workshops worth taking your pride and joy to for tuning, servicing, modifications in or around Canberra.
Done :)
  • 4 months later...
Done :)
Hey guys,
Looking to get a nistune ECU for my Stagea. Nistune because I'm budget conscious.. but I havent been able to find much info on who in Canberra has experience tuning these things. I walked into DTS today and they had no idea what I was talking about.
I've searched SAU, but was looking for some local (ACT) knowledge and/or opinion.
Thanks for that. The reason I highlighted techworkz was because they're close to my work and just convenient for me. I'd love to get my car to ESP or Trojan as they are known for working on RB's, but unfortunately unable to get there without it interfering with work.
Ill give them a call and suss it out.
Ok.. so turns out that they don't do any tuning because they don't have a dyno. They're happy to install etc, but organise tuning via ESP. *sigh*
Why would that be a problem?
Drop your car off at Techworkz for a day or so and then pick it up when it's done... They'll take it to ESP and have it tuned for you, it's a win-win situation :)
I hate this thread - there's heaps of comments in here on people's thoughts on workshops. Obviously the bad stuff can't be written.
I think we should lock it like they do in NSW when people ask these same questions. People need to call around and make up their own minds because all workshops come with good and bad stories.
send it to sydney and use it as an excuse for a day trip up there
Isn't there some discussion about having it tuned locally vs interstate? The whole air pressure at home and all that?
lol, but dont get me wrong.. love a roadtrip.
why would you pay for a contractor to add a margin to someone you can deal with direct?
Most likely will head over to ESP and get it tuned and all that by them directly. I am after convenience, but at the same time I want to save $$$ anywhere I can.
The whole reason for this is because I was just after convenience.
I hope I didn't come across like I didn't like one shop over the other, I just wanted to see what option best suited me.
  • 6 months later...
  • 1 month later...
Not this thread again! Lol.
I was wondering if there was a tyre shop around that treats cars like 'ours' with care. The reason I ask is because this particular shop in Tuggeranong, where i took my Stagea to, sped up to the hoists and smashed the front lip against the ramp. EVEN after I pointed out that it may happen! Not to mention that he sat in my car and finished the last puff of his ciggerette and threw it on the ground.
I will soon be buying new rims and will require rubber for them, and I would like to bring it to a place where I will have piece of mind knowing the rim and finish won't be damaged and my newly repaired front lip will not cop a beating. heheh!
Please feel free to PM me to avoid the inevitable debate.
  • 3 weeks later...
  • 2 months later...
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
