could be the clear coat coming off
sometimes that can make it look like a respray in areas
I think it definitely is in some places.
Though I found some black spray paint on the front passenger window which sparked my thinking.
Haha very wary of crossthreading, all good!
But yes, my delicate hands were not made to work on the GTR. I have 2 small grazes, a bump on my arm and a small chunk of skin missing from my finger but GTR now has fire extinguisher!!
Get yourself a few pairs of these >> http://www.signet.net.au/store/products/40857/ansell-hyflex-11-618-gloves-size-9-12-pairs-per-box
or similar for working on the car, we have to wear gloves at work and I borrowed a few pairs for home. I've gotten so used to working in them I feel like something is missing if start playing with the car without gloves on.
Pulled the Twin Turbo pipe off and the Apexi intake pipes for polishing.
Also getting Sin's old polished plenum re-polished as well.
Only thing I could get off is the rear turbo elbow pipe. May have to paint this black!!
Washed and started polishing the SkyHatch but not finished...
Got involved in much more exciting things like pruning the roses but did a Green Waste run in it. Practical it is.
I'll finish it of tomorrow and Vac.
also got my N13 Haynes Repair Manual today for $20. :D
Started the skyline for the first time in a few days.. It really wasn't happy and was running on 5 cylinders for a few seconds. I'm guessing it will only get worse if I leave it for longer periods..? Any recommendations?
Might check the plugs when I get a chance, it's almost been 10k.
Edited by dontyellpl0x
I don't have any problems starting the GTR after longer periods besides battery (problem solved leaving trickle charger on it).
I also don't remember the last time I got 10k out of a set of plugs! :)
You mean like tuning it up to the edge and drag racing? :yes: Yeah, that will give the plugs a hammering.
Sold VC commodore today for a small profit :yes:
Not an easy thing to do these days. Nice one.
Gave mine a quick wash, its losing gloss in some areas, maybe its just the wax, but it will get another polish soon anyway.
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
    • Back pressure is not really a function of the exhaust itself, but the turbine/housing. So the question/point remains valid. I would be fitting an EMAP tapping point and seeing what is going on in the exhaust manifold before committing to throwing boost at it. Flow. No intercooler is actually rated for continuous operation at any power level wrt temperatures, as they are no actually capable of shifting the required amounts of heat on a continuous basis. They get hot during a pul, then dump some of that heat into the external air (and some back into the internal air) during off load moments/periods). You probaby do need a bigger core, given the power level you're already at is somewhat above the "rating" of the cooler. Put pressure tapping points either side of the core (which possibly you already have, if you have a boost source near the compressor outlet and tapping near the throttle for existing purposes) and report on delta P across the core.   I haven't done the mass flow calculation to see where you would be sitting on the compressor map at the ~450is rwkW level we're talking here, but if you look just at the PR you're running at, which is ~2.8-2.9, then you have a really really wide swath of the compressor map to run in, and so long as you were making between about 45-75 lb/min of flow, you should have really good comp efficiency, with the ideal being betweem 55 and 65. I can't see the need to shift drastically on the map to get better results.
    • Welcome 🙂 The ER34 wheels and slight lowering suit the R33 sedan really well. I'm firmly in the 'keep it stock, at least on the outside' camp.
