I think I can post here too now.....
As of yesterday....
  • Model of car V-Spec II, Built Oct 94
  • 'Chassis No' code BNR32313245
Also sourced from the Iron Chef (I think i can blame Cherry Racer - they teased me with a picture of his car as one of their recent imports ;-)
Short details:
Silver
Stock
Single owner
17,300 kms (full documented service history)
Grade 5A at auction
Obviously still in Japan so here's the auction snap (already plastered in other part sof the forum - but just so happy right now ;-)
Cheers
The Baron
That looks amazing Baron. Awesome.
The headlight thing will polish out.
Whereabouts are you based?
The headlight is a bit odd, but I am confident it is nothing serious - more detailed pictures are expected tomorrow....... not too worried considering the provenance of the vehicle.
Will be based in Melbourne eventually.
Cheers
The Baron
Cheers
The Baron
Andreas, congratulations on your purchase. That is a rare find.
I know when I bought mine Steve at JJ said to buy it (advertised privately) because for him to get me one I would have to take what he could get, be it a $15k POS or $30k stunner. That was 3+ years ago now.. I still can't find words to describe how jealous I am of the latest edition either..
Edited by iplen
Rare enough that I thought we'd never find anything similar after we got Cherry Racer's car. This is once in 2 years-type.
I am eternally grateful ;-)
Cheers
The Baron
Holy crap! That's awesome.
We need to find you some nice mats Baron.
Are there reflectors on the rear edge of the doors? Were they an accessory?
Love the wind deflectors still in place.
I wonder what the following items are:
- object top left of dash, near left a-pillar
- object in passenger footwell
- recangular object to left of steering wheel
So cool! Sweeeeet car!
Absolutely beautiful!
Can someone tell me what the sticker is on the radiator fan shroud with the blue circle/dot?
Mine previously had it but no longer. Trying to track one down.
If we can get a close up, might be able to decipher. AC refrigerant label/type?
no idea on that yet - I believe from some of my japanese collegues at work that it could be some type of 'e-tag' tolling thingy......
that's a bin (yup - odd I know ;-)
- thats the connector of a cable dangling out of the centre vent - apparently connected to whatever was sitting on a mount on the centre dash - see attached picture for opposite side view. will be a pain to get rid of the mount I fear - depending on glue.....)
any ideas on where to find one would be apopreciated.... :-0
Cheers
The Baron
I would be trying to track down an original radio too Baron.
Very nice.
Mine has marks from similar aerials on the rear screen and from something having been glued to the dash in a similar place (but slightly different shape of "foot print") which was all part of an ancient and massive GPS system, the dash mount was for the screen, the aerials were for TV, the object on the dash might be GPS antenna. Mine still had the screen in the glovebox, but it was confused as all hell by being in Aus.. The mark on my dash is pretty hard to see where they took the mount off, it does however literally look like a boot mark, and raised a few questions when I first looked at the car..
  • Like 1
Well the auction sheet apparently mentioned a similar navigation system so it'll be interesting to find out exactly. Maybe my screen is still in the glove box too....
Cheers
The Baron
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
