I think I can post here too now.....
As of yesterday....
  • Model of car V-Spec II, Built Oct 94
  • 'Chassis No' code BNR32313245
Also sourced from the Iron Chef (I think i can blame Cherry Racer - they teased me with a picture of his car as one of their recent imports ;-)
Short details:
Silver
Stock
Single owner
17,300 kms (full documented service history)
Grade 5A at auction
Obviously still in Japan so here's the auction snap (already plastered in other part sof the forum - but just so happy right now ;-)
Cheers
The Baron
That looks amazing Baron. Awesome.
The headlight thing will polish out.
Whereabouts are you based?
The headlight is a bit odd, but I am confident it is nothing serious - more detailed pictures are expected tomorrow....... not too worried considering the provenance of the vehicle.
Will be based in Melbourne eventually.
Cheers
The Baron
Cheers
The Baron
Andreas, congratulations on your purchase. That is a rare find.
I know when I bought mine Steve at JJ said to buy it (advertised privately) because for him to get me one I would have to take what he could get, be it a $15k POS or $30k stunner. That was 3+ years ago now.. I still can't find words to describe how jealous I am of the latest edition either..
Edited by iplen
Rare enough that I thought we'd never find anything similar after we got Cherry Racer's car. This is once in 2 years-type.
I am eternally grateful ;-)
Cheers
The Baron
Holy crap! That's awesome.
We need to find you some nice mats Baron.
Are there reflectors on the rear edge of the doors? Were they an accessory?
Love the wind deflectors still in place.
I wonder what the following items are:
- object top left of dash, near left a-pillar
- object in passenger footwell
- recangular object to left of steering wheel
So cool! Sweeeeet car!
Absolutely beautiful!
Can someone tell me what the sticker is on the radiator fan shroud with the blue circle/dot?
Mine previously had it but no longer. Trying to track one down.
If we can get a close up, might be able to decipher. AC refrigerant label/type?
no idea on that yet - I believe from some of my japanese collegues at work that it could be some type of 'e-tag' tolling thingy......
that's a bin (yup - odd I know ;-)
- thats the connector of a cable dangling out of the centre vent - apparently connected to whatever was sitting on a mount on the centre dash - see attached picture for opposite side view. will be a pain to get rid of the mount I fear - depending on glue.....)
any ideas on where to find one would be apopreciated.... :-0
Cheers
The Baron
I would be trying to track down an original radio too Baron.
Very nice.
Mine has marks from similar aerials on the rear screen and from something having been glued to the dash in a similar place (but slightly different shape of "foot print") which was all part of an ancient and massive GPS system, the dash mount was for the screen, the aerials were for TV, the object on the dash might be GPS antenna. Mine still had the screen in the glovebox, but it was confused as all hell by being in Aus.. The mark on my dash is pretty hard to see where they took the mount off, it does however literally look like a boot mark, and raised a few questions when I first looked at the car..
  • Like 1
Well the auction sheet apparently mentioned a similar navigation system so it'll be interesting to find out exactly. Maybe my screen is still in the glove box too....
Cheers
The Baron
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
