For every ones info. I replaced the V Spec II sticker on my car, with a genuine Nissan sticker. It was super expensive, but aside from that, the sticker is shaped to match the corner of the back boot like a template. This means that you can use the corners and edges of the boots to get the sticker in the exact factory position. Pretty sweet. I was surprised.
Just checked my spare sticker (my original is just showing a tiny amount of peel on one corner....) - you are right - how clever of them......
Cheers
The Baron
PS That Edward Lee Video should be pinned somewhere as a "must see" for anyone who ever considers buying a car from that guy, with annotations about all the misleading statements.......
Good luck this weekend Bob! :D At the very least I'm sure you will have fun!
Yep had fun but my times were ..........OK????????
My best 1/4 mile was 13.399 (slip attached) but my best terminal speed was 178.94 kph a couple of runs later (111mph).
With that speed I should have been well into the 12's but my 0-30' times are horrible.
I just can get it off the line. I tried it in 2WD mode by pulling the fuse but that was worse!!!!!!
I just sat there and smoked the tyres. :closedeyes::closedeyes::closedeyes::closedeyes::closedeyes:
Anyway, I flogged a few of my mates in stock HSV's and GT Falcons (mid to low 14"s)!
Cheers,
Bob.
Its all in tyre pressure Bob. Need to be 15psi from memory, can't remember exactly but it's a super low pressure.
Once that is set, 2nd gear burn out in rwd mode then flick to awd, on the limiter and release the clutch...when it hooks up you will be shocked what g's these cars can pull on take off.
Mine did a flat 13 when it was stock as a rock...won't get much better than that although I've heard they run a PB 12.8
Thanks Marko,
Modern Motor (April 1990 issue) ran a 13.1 stock........ That's the best I've seen in any publication. Most run around 13.7.
My tyres were set at 27psi for the fronts and 22 psi for the rears...... Guess I stuffed up on that one.
I normally run them at 34 and 30 on the road.
Was pleased with the terminal speed though.
Bob.
At 111mph it's not stock and probably making closer to 270kw at the wheels and should be doing flat 12s or even into the 11s
100% correct........ Unigroup dyno'd it at 271.6 rwkw.
Bob.
what is not stock on the car Bob?
Bar the exhaust, (3.5" front Pipe, 3" Hi Flow Cat, 3.25 Rear pipe, 3 and Hiflow rear muffler) everything you CAN'T see.......
  • Nistune
  • Sard 720cc injectors
  • Lager Walbro fuel pump
  • HKS Boost Controller
  • Splitfire coils
  • Excedy HD Clutch
Bob.
  • Nistune
  • Splitfire coils
  • Excedy HD Clutch
Bob.
nice. The Walbro pump is not to noisy?
No....... The exhaust must drone it out!
A mate of mine had a Brock Commodore VK Group A that was tricked up with a Walbro pump and that was horrendously noisy so I know what you mean.
Bob.
Cheers,
Bob.
That's still very respectable, and at least you had fun... that's the main part!
How were you launching the car Bob? These things need a little tough love from the start line, you might feel bad in doing it but it's what she's made for :) There's absolutely more to be had from your car, your 60 foot time of 2.1s could come down to 1.6 to 1.8 seconds with a bit of practice - I'm not a drag racing expert by any stretch of the imagination but that little bit shaved off the front end often seems to translate to a larger amount shaved off at the other end.
Well done in any event, at least you came out the winner against the HSVs and FPVs! :)
  • 1 month later...
So just an update on my gtr,
Installed new timing belt, HKS cam gears, water pump etc,
Bought a power fc and some hks 550cc injectors.
I had a second hand apexi avcr so I just used the boost solenoid and wiring and converted it to my power fc.
Got the car back from the tuner today and made 265kw's on 1.1bar boost!
Pretty happy and the car feels a hell of alot more alive than before!
  • 3 weeks later...
Hey guys,
I've been off sau for a year or two. Sure we used to have another rare register with a good record of vpsecs and n1s? I'm probably just lost tho, lol.
Anyway adding for the community, in Brisbane with a 1994 Vspec II N1. Unfortunately not very standard! :-)
Cheers
Michael
Fortunately, Australia has acquired 2x BNR32 V-Spec II N1 in recent times.
Congratulations to you Michael as well.
We'd like to grab them before Canada's timeline permits...
Last six digits on mine are -311603
It's still awaiting compliance.
  • Like 2
is that a genuine N1 Terry?
Car looks very nice.
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
    • Oh, and as for everyone with their fuel economy changes, I switch between E10 and 98 in the company car. Even do when I had personal cars that could run on E10. You know what changed my fuel economy in any noticeable way? How I drove, and where I drove. Otherwise, say on full tanks of just back and forth from work only (So same trips, same sort of traffic), couldn't notice a difference that I can correlate to the type of fuel in use. In the current vehicle, that's over 42L of USABLE fuel. While 98 is all "more energy dense", it also has higher knock resistance as it takes more energy to get it to ignite too. The longer hydrocarbons, typically more tightly bound. So running the same ignition map, can also produce less power, if there isn't enough time to get it all burnt through properly, as yep, the flame propagation speed is different from lower octane fuel to higher (Higher has a lower flame propagation, due to the more tightly bound and harder to self ignite funs. This is also typically where, a vehicle that is designed purely to run on 91 (Whether it be E10 or normal 91) usually sees absolutely no real world difference in fuel economy for the normal man, woman, or dog.
    • We've got some servos around me that have 91 with E10, 91 (no E10), 95, and 98. At those stations the change from 91 E10 to 91, is typically around 8c/L.   But lets not get started on the price of fuel in Oz. It's ridiculous. All the service stations around me, bar one, the price of fuel has been over the $2 mark per litre for the cheapest, 98 being around $2.45. That one service station is a CostCo, fuel from it comes from the same refineries, and makes no pitstops, it runs great, including the 98. In fact, I've had no issues on CostCo fuel, but plenty of issues at other stations!. The CostCo fuel, was $1.65 roughly this week for 94 with E10. $1.88 for 98. Servos directly across from it, $2.10 for 91 E10, and $2.48 for 98. The part I had to laugh at? If I drive multiple HOURS away from Brisbane, say out near Nanango, or Kingaroy, or even out to Goondiwindi, the price of their fuel, is the same as what it is at the CostCo... Oh, and that BP servo at Goondiwindi is HUGE and goes through epic turnover of fuel, so it's not sitting there for weeks going to shit. And what blows me away, my mate is one of the people who drives the Fuel Tanker all around QLD, delivering to all those places. At the same company his previous role was doing the "local haul" deliveries... Same truck, same driver, same pickup point it all comes from. So you tell me, how the hell it is 60c/L CHEAPER for fuel, when nearly all else is equal, except they require a B-Double to drive half a day out of Brisbane, and half a day back, every second day, compared to the delivery that can be under 30 minutes drive from the fuel pickup point... Not to mention, go five blocks down the road, and Ampol to Ampol will vary 30c/L... And I've had this conversation with my mate... The way it's priced, is just typical, pure and utter rubbish... He also does runs from Brisbane, to all over QLD, down to Newcastle, Sydney, Nowra, Melbourne, Geelong, and even out to parts of the NT depending on the companies needs. His main stuff is all the longer distance away from home for a few days at a time, then when he's back, he loves to just pickup extra shifts wherever he can in whichever truck, hence all the weird different places.   Oh, as for getting E10 into all the fuels in Australia... It was very quickly highlighted, that we don't have enough biomass available to use to make E10 sustainably like they require, and it would dramatically cut into our, and the worlds food chain supply...   I vote we all just start running on liquid methane gas... Plenty of that just getting tapped off at tips from underground decay... (Note, this is pure just stupid commenting. I could very easily highlight the reasons its not a good idea especially on scale...)
    • Am I correct in assuming that the R35's are getting the classic skyline haircut off the odometer?  Quick search on carsales, there are 33 08 and 09 GTR's for sale, only 2 of them have more then 100,000km's on them (116,075 and 110,000 respectively).  And somehow there are about 25 for sale with around 60,000kms? Looks like the classic skyline haircut to me =/
