Thanks for the comments,
got the titanium from titanium joe in the US.
yeah it is purged brad and i got a trailing gas setup on the tig torch but your never going to get perfect coverage with it, and i dont do enough to justify buying a bag.
i did think about making up a box to weld it in but that is alot of work for one front pipe.
for those that dont know titanium ideally needs to be welded in an argon bag/purge chamber as it reacts to the atmosphere way more than most other metals that i know of.
yep lots of patience
Very Nice work mate :woot: , we are about to start construction of our 4" Titanium Dump pipe/side pipe for drag car cut all the rings up for lobster bends this week. Just gonna fusion weld the joins and with trailing gas attached to the hand piece, pretty simple really. Will post pic's when we do it.
all up it cost about $1000 not exactly sure as i bought a bit extra titanium for a few other things,
the 75mm tube was $400 delivered and that was with about 50mm left over
the 100mm tube and plate for the flanges was about $150
the 100mm titanium v-band was $150
and i used a bit over 1 G size argon at $300 to refill
so it was by no means a cheap exercise but then again the only equal length titanium front pipe that i've seen is the mines one and they are over 2 grand and only
have an 80mm outlet or something.
the midori one looks like good buying for around $1350 or so but thats not equal length and only 90mm outlet.
I have no idea if the equal length does do much for the performance or not but i just done it because it can't hurt and i could.
it was worth the money just to hear the sound of it, and also for anyone wondering it weighs 2.6kg
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
