Looking good. One thing I always thought about doing is trying to paint those cards that sit in the bottom of the doors.
But I'm to lazy for that.
Hmmm, you had to put the idea into my head didn't you? ;)
Looks like the cardboard cards are fairly easy to take out just a few screws.
I was careful not to pull the factory glued vinyl off them to separate them from the door.
Went and got some 3D Black Carbon Vinyl Wrap today. Just got some cheaper stuff from Supercheap as those pocket cards are a bit hidden.
Cut to size and layed over. Getting the bubbles/lines out is fairly easy.
Back in and all screwed up. Gives them a nice subtle look. I used some Kiwi Grip spray contact adhesive as the door cards are chipboard with only a thin layer of paint between that and the wrap adhesive. Goes on stronger that way.
  • Like 3
10kw more than me. Damn you!
Don't think it'd make a difference in the real world, man :)
You running -9's? Got a link to your graph somewhere? Wouldn't mind taking a look, esp at what the boost curve is like.
Nah -7's. Standard actuators and afm's hurt my power.
Chris told me it made around 340rwkw but I told him to back it off as it's a track car and I wanted it to be safe.
That's good power for -7's, man. The final tune I got is a track safe tune also. Looking forward to finally getting it on the road and then to some events this year!
I'm not complaining. I've got to learn how to drive before I get more power.
I Should hopefully have my car on the road for the 1st time tonight and 1st track day of the year on Saturday. Man I'm excited!
  • Like 1
Hey mate,
I've so far had the car back at 3 power levels. 298,312 & 335awkw
Compared to how I first got the car back in 2005 (standard ceramics boosted to the max - 260rwkw), the -9's are definitely a bigger turbo and respond accordingly. The -9 setup in my car pulls all the way pretty much to redline unlike the standards which hit a wall near the top end. (and you could feel it)
Depends what you're after- purely street i'd go -7's for a 2.6L. I want to eventually get some events under my belt so wanted that little bit extra so went -9's as I had all the supporting mods.
That said look at gtr jet, he got 325kw with his -7's. Awesome.
How was the first drive Shivam? Still tossing up to go -7s or -9s, still leaning towards the -9s.
daaaaaaaaaaaaaaaaaaaaaaaamnnnnnnnnnn Shivan that looks bloody amazing.
Such a simple mod with such striking results - I think Ima gonna give that a crack as well mate ;)
Got an e-mail from Racepace. Final tune is done. Very happy with the result.
Brilliant results mate really happy for you. They are sensational numbers :thumbsup:
Go for it, guys. Easy and takes less than an hour.
Thanks mate, the -9's are pretty much maxed out now. It made far more but it's been dialed back for a track safe tune. Very happy with it, feels great and can't wait to start on a few events this year.
Going to spend the next couple of months neatening a few things and getting it ready for Road or Club reg.
Wow awesome turn out with the tune/power output. Good &
solid number. All that hard work has finally paid off.
Can't believe how good them door cards turned out,
Definitely adding that to my to do list. Good work man.
  • Like 1
Not maxxed them just yet ?
They are great on the track you will love them even more
Also got some Superior Auto Creative Carbon-Look Sun Visor Cover set to cover up the tatty OEM ones.
Nice looking Man's bag ...... can i buy one and wear around my waist instead of using it as a sun visor?
J/K
Good working progress, hope to see this beast on the street sometime.
  • Like 1
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
