IMO get an OEM R32 GTR steering wheel for street and just swap that Sparco wheel on for when its tracked. OEM all the way.
Agreed. OEM one is pretty good.
Finding one that isn't shagged is another thing :)
Have a look into Nardi Steering wheels.
I got one.
Always wanted an OEM steering wheel.
Simple / looks clean and does the job.
But I got a Nardi, can't complain, I guess.
I'll take a geezer.
I rather like that Sparco one as it does feel great to use.
Like I said, I have been quietly getting work done on a replacement......hopefully some sneeky pics soon! :)
  • Like 1
don't be silly boys..........just get your original OEM steering wheel restitched
like this Robson leather - cost approx $300
you can get it with red stitching too ;)
  • Like 2
Some photos from the event.
1960881_10152054375322734_901571917_o_zp
1799982_10152054370092734_974164642_o_zp
Sun in my eye!
1781358_10152054498867734_1332399294_o_z
Black & White - PaulR32GTR's car after we had a Motorkhana battle. What an animal!
1891373_10152054438592734_346939167_o_zp
Car ran perfectly all day without a hitch. Very happy with it.
Possibly a hill climb next, followed by a track day but before that some changes coming next time she goes into RPM for a service.
  • Like 1
Sun in my eye!
very nice shivam. Love the rear end of them R32's
Paul's car is also sweet
  • Like 1
  • 1 month later...
Small and subtle update. Just got the car back from a service. Some minor things repaired/replaced here and there. Discovered that I had to get the rear drive shaft reconditioned. "Replaced centre bearing, machine flange to suit spicer 1350 universal, rebuild CV and replace boot, balance assy"
Shiny new driveshaft.
Now for the visually subtle but big change to the car. RPM transfer case mod. Transfer case has been rebuilt. Additional clutch plates and a few other changes internally, I believe. Also 4WD system modified, running more pressure.
Does it make a difference? Hell yeah! 4WD comes in sooner and harder and it's lost quite a bit of the 32 GTR "tail happy, laggy 4WD system" character. Have a Haunted Hills hill climb event coming up so can't wait to really test it out. Can't believe I hadn't done this mod sooner. Next stop, Nismo front diff!
  • Like 2
That is sweet Shivam.
Can you pm details on transfer case mod i.e. costs etc....
def sounds the way to go.
Nismo front diff - should also be another epic mod (although I will go with Quaife) :thumbsup:
Saw your Quaife diff. Win! Will make a big difference going from 3WD>4WD on these cars :)
RPM mentioned that they modify the Nismo diff a little bit before it goes in (didn't ask what at this stage)
PM on the way :)
  • Like 1
You'll most definitely appreciate the transfer case mod.
Running with new tyres at Winton on the weekend made it more apparent just how slow the 4WD system is from factory. Wheel spin city!
  • Like 1
Few changes to Victorian club permits around the corner and a few other things happening as well atm. Instead of doing lots of events over the next two years in full roll-cage trim, have decided to slowly change it to a full registered road car in the next few months.
Have had this sitting around for a while. Standard steering wheel with sewn on leather cover. Will go on after the Hill Climb event this weekend at Haunted Hills.
  • Like 1
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
