Glad to have met you on the SAU cruise mate. Good work on the updates, your car looked great and I'll make sure to bring mine next time round it has no issues.
  • Like 1
  • 1 month later...
RBN1 from bitter experience - drive it as much as you can.
took my dirty stinking datsun to Sandown (drive it about 4 times a year) and in the first session developed a misfire (coils/ ignitor).
thing is these things are simply getting old and maintenance starts to add up...
Shizen. When was this?
Speaking of these cars getting old. Found this last night.
Front right driveshaft. Oh well RPM did mention that they needed looking at last time it was in.
easy fix that brother. go down to your local Repco dealer and ask for an outer CV boot for an R32 Skyline (they will match it to a Toyota Part no.) - they cost $13 bucks (by two to make with worth your while) and comes will all the grease and clips (although I believe the clips don't actually fit so retain the orginal ones or just buy them new) and you should be all good to go.
I had to replace mine last month and thats what I did.
  • Like 1
the man loves his genuine tho....
i found it easier to just replace driveshafts man. yea they are more expensive, but you know youve got brand new cvs etc on there.
plus they are much easier to swap than changing a boot.
replace drive-shafts ok................then add GTR tax and your really getting reamed.
the left outer boot is much easier than the right outer boot to undo as you only have six bolts to do undo and yank it out.
peace of le cake
Car is f**ked. I would just replace the entire car. Easier than doing anything on a GTR....... :whistling:
Considering the age of the car i would weigh up replacing the whole shaft. don't want to go back in 6 months.
edit: keep in mind i has no idea on how much that $$$$$
Edited by Anfanee
Although I understand what you are saying Anf.
If the drive shaft is in good condition there is no need to replace it. Just ensure it is promptly cleaned and lubed before whacking it back in (kinda like a dirty hooker really)
10 bucks says he swaps the whole shaft lol
its what? 300 bucks? all new, all genuine....
you know me fellas, im all about cheap and nasty. but OP is not.
Ewwwww but yeah.
LOL.
Spoke to RPM this morning about replacing it. It's due for a service anyway :)
I almost forgot to put up why I was under the car in the first place.
Decided to pop the side skirt off to see why one of them has popped out and get them both replaced with the genuine N1 3 Piece items i'd bought a while ago.
Ended up being a good news, bad news moment.
Good news was, no Rust under the skirts.
Bad news was:
Front left jacking point : No wonder the skirts popped out. The sills collapsed a fair bit from what looks like, careless jacking. Have straightened the seam however, will take it to a panel beater to get it pulled out after next service.
Top view. Skirt can't adhere to the body as the sills bent in, towards the car.
Pesky GTR's.
  • 3 weeks later...
Hmm forgot I had even ordered these until it arrived this morning.
I think I have a problem. Note to self - no more late night scotchs and sitting in front of the computer.
Carbon fibre coated interior pieces.
  • Like 2
Hey rbn1,
Would you mind looking at the part numbers on the front section of the 3 piece side skirts? The small sections that attach to the bottom of the front guards. I need to order some from nissan and haven't had much luck on Google.
Thanks mate and keep the updates coming!
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
